Tugnuts?- Mtbr.com
Results 1 to 7 of 7
Thread: Tugnuts?
    Reputation: 2big2ride's Avatar
    Tugnuts?
    Do you need the Surly tugnuts With the horizontal DO's? I'm getting a 1 X 1 frame and I trying to figure if I will need a tensioning device.
    How tight should my chain tension be? This is my first time without using a springy tensioner.
    Thank for the help
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    If your using a quick release wheel I recommend them - bolt on wheels usually have no problem.
    Hope that helps
    FF
    "If I'm leading, I'm bleeding."
    Paintbucket
    I use a tug with a bolt on wheel on a 1x1. Better safe than sorry....
    Zippy for president
    I agree
    For $25 you get a nice bottle opener and it helps set things up. You only need 1 on the drive side.As far as how much tension, spin the crank backwards by hand. I would say you want about 1 1/2 to 2 turns of spin with a pretty good throw.
    Ride what you want!!
    Reputation: george_da_trog's Avatar
    Jul 2003
    Just slapped one my my Bass and I have the bolt on hubs. Helps me set the tension.
    george
    Trogs: Too Tough for Carbon Fiber
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Redline makes some nice ones
    Quote Originally Posted by 2big2ride
    Thank for the help
    And there cheap.
    Quote Originally Posted by wooglin-at-home
    whole heartedly agree. it helps with getting your wheel in straight as well.
