Top tube damage- Mtbr.com
Results 1 to 16 of 16
Thread: Top tube damage
    Top tube damage
    During today's ride i managed to turn my wheel to a 90 degree angle causing me to fall of into the small creek next to the trail. My bike (IRO model 19) fell hitting only the top tube on a big rock.
    Is this damage going to cause me to fall flat on my face with the bike in two pieces? (it is a steel frame.)
    This makes me mad because this frame is new.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Ride it , seen alot worse than that . Too bad about the damage , but it could be alot worse .
    That is what I planned on doing. I just didn't know if it had weakened the frame at all.
    IROs have shitty paint. Get some black model paint and touch it up. You won't notice it. It's structurally fine.
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    That's far enough from a high-stress area that I think you'll be ok.
    It adds character!
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    Teen Wolf
    Reputation: cr45h's Avatar
    dood that sucks. i'd be pissed as hell!
    Out spokin'
    Dec 1999
    Bummer about the cosmetics but that's all it is.
    --Sparty
    disciplesofdirt.org
    Reputation: Yuengling's Avatar
    Its chromoly.....you're good. It gives it character.
    Cannondale Caffeine 2 29er
    Redline Monocog Flight 29er
    Fuji RC Team
    Kona Jake the Snake
    Blk Mrkt Mob
    Badge of Honor
    I like big bars and I cannot lie
    If it was aluminum I would be worried, but it is not!
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    Put a sticker over it!
    The most important thing is what God thinks about it. He will have the final say. Joshua Stinebrink
    ____
    Kimo
    PSYCHOLUST
    Reputation: scyule's Avatar
    Looks like a good place for a STICKER
    I going to ride it today so i'll know for sure
    Let's get weird
    Reputation: kampgnar's Avatar
    Had a ding in the center toptube of my el Mariachi, very small, smaller than a dime. Cracks began to form at the ends/creases and propagate outward. Not a whole lot of movement, but I stripped paint from the area and hit it with a thick primer to get a better idea of how quickly it was moving.
    I kept an eye on it until the down tube broke 2/3rds around in diameter at the ht gusset...then I didn't have to worry about it anymore.
    I replaced the front triangle with Verus and Verus ht tubing, larger diameter downtube, thicker butting profile all around, and it's better than the original.
    Reputation: ernesto_from_Wisconsin's Avatar
    Fuuuuuuudge - You'll be ok as well as the frame. Steel's better than butter, so you're ok.
