tool for WI eno freewheel- Mtbr.com
Results 1 to 19 of 19
    1*14*29*2.1 & 1*1*29*2.4
    I posted this question in another forum on another older thread but it doesn't seem to be getting any answers so I thought I'd try here....
    I bought a tool for my WI freewheel, but it doesn't quite fit Is there a tool you guys recommend? There seem to be a few out there but I am not sure which...I want to avoid spending $25 plus another $25-50 on postage. Thanks.
    one chain loop
    Reputation: fishcreek's Avatar
    Park tool fr-6, isn't it?
    everything sucks but my vacuum cleaner.
    Riding rigid
    The WI Eno tool is machined out to clear the eccentric axle. But if I remember correctly, the pronges are a little slimmer than some freewheel removal tools. I can check on this when I get home.
    one chain loop
    if he is using an eno hub with his eno freewheel, then he can pull out the eccentric axle first then use the fr-6.
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    Quote Originally Posted by fishcreek View Post
    Yup. You don't need the special freewheel tool to remove the ENO freewheel. OP, do you have the ENO hub or standard?
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
    Thanks for the responses everyone. Fishcreek...thanks if that is right it'll be an option I should be able to find. No, I just have the WI trials freewheel...it's going on a Paul word disc hub which is coming. Hope that helps.
    I've found a possible tool, but wanted to check with you guys first. Wiggle says it will fit, but knowing how communication works, a double check is a good idea. Benefits are that it is cheap, and it's likely I can bundle it in with a future purchase so won't have to pay postage.
    wiggle.com.au | Cyclus Suntour 4 Prong Freewheel Remover | Workshop Tools
    nothing to see here
    Reputation: Stevob's Avatar
    That's not going to fit. The prongs are too wide.
    I see hills.
    I want to climb them.
    Thanks stevob...something a file can fix? The inside diameter seems to be the crucial measurement. When I measured the freewheel with callipers, even the park tool specs weren't prefect as the inside dia was about 2mm bigger than the freewheel. Would probably still work though.
    nothing to see here
    Absolutely a file could fix it. If you're prepared to give that a go.
    edit...the only thing is whether you can actually get a file to the face that needs filing. The other prongs may be in the way, depending on the thickness of the file.
    I see hills.
    yeah...I've done much scarier stuff before. May be worth a try thanks for the input.
    Wait, so why won't the FR-6 work?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Sorry if I missed it, but why not use the WI tool?
    Riding rigid
    his shop probably didn't have a WI tool available, so he picked up another freewheel tool but it doesn't fit the WI freewheel.
    I dropped the ball checking on my WI tool. I'll remember to do that tonight and report.
    nothing to see here
    The tool from Wiggle was $5 as opposed to $25 and he can bundle it with his next purchase and save more on shipping
    I see hills.
    AZ
    AZ is offline
    Got it.
    Riding rigid
    I have the Park FR-6 also, it should work, there is just enough (1.5mm) to catch the edge but you want to make sure the FR-6 is secure otherwise you will tweak the edge of the freewheel.
    The inner/outer diameter on the
    FR-6 is 32mm/40mm tooth width is 8mm
    the WI is 30mm /35mm tooth width is 8.5mm
    The WI freewheel inner is exactly 30mm and outer is 35mm. The WI tool is a snug fit. With the FR-6, there is some wiggle and the whole profile of the freewheel is not engaged.
    Quote Originally Posted by MTB Pharm View Post
    Thanks for the precise reply...takes the guess work out. As I guess I won't need to take the freewheel off in a hurry...unless I screw something up...I'll wait for the bundling option I think. The WI tool looks nice but for $5 I may take a punt on Wiggle. I was told by Universal Cycles that the ACS is the other good option, but they have been out of stock for some time. Same reason I didn't get my Paul hubs through them which is a pity.
    If the Wiggle tool doesn't fit at least as well as the Park, I'll probably search out the ACS. Cheers.
    Quote Originally Posted by Stevob View Post
    Acutally yes I was hoping to just file the non working edge but that may not work.
  1. Park tool Poly lube 1000 on freewheel ratchet
    By Learux in forum General Discussion
    Last Post: 04-11-2013, 09:01 PM
  2. Appropriate Tool for Freewheel removal
    By pearsth in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-31-2012, 09:45 AM
  3. Replies: 4
    Last Post: 12-29-2011, 09:05 AM
  4. Giant Tool Shed Multi-Tool - Ten Bucks - incl. chain tool
    By aa240sx in forum Where are the Best Deals?
    Last Post: 06-23-2011, 11:17 AM
  5. Bottom Bracket tool and crank tool questions
    By RBikerSD in forum Tooltime
    Last Post: 01-10-2011, 04:36 PM
