Tool question re:single speed- Mtbr.com
Results 1 to 5 of 5
    New question here. Tool question re:single speed
    hello fellow singlespeeders...i just converted my hardtail to a singlespeed and have a question or two...first i need to add another spacer which i have but i tightened the lockring pretty good..i have the removal thingy but not the chain whip...is there a way to take it off without the chain whip..i have a spare chain if that will help. also how tight should the chain be..i have it pretty tight via a singulator and when turning the cranks it seems more rough than smooth...could also be that i need to lube the chain..any help would be great..ill post pics when i can...
    Reputation: Zion Rasta's Avatar
    You are better off buying one
    Quote Originally Posted by mikieboy
    Go to the bike shop and buy a chain whip tool, they are cheap. Or if you dont have $10.00 borrow it at the shop and use it right there.
    So far the best tensioner I have used is an old deraileur. I have tried 3 different tensioners - surly, paul, ringle and they all skip when I hammer, even with a perfect chainline. I have climbed impossible hills with a 34x18 and derrailleur for tensioner and no skips. the derrailer sounds so sweet and smooth. I may try ENO hub but I can not justify the $140 for it since my derrailleur does the job perfect.
    Sit and spin my ass...
    Reputation: pacman's Avatar
    Try this
    If you have the flat-faced removal tool, not the fat socket type, place the tool on the cassette and put the wheel back on the bike (with chain of course). The crank arms will take the place of the chain whip.
    Reputation: the Inbred's Avatar
    yeah, the chain whip is pretty handy. i'm glad i got one, finally.
    also, Zion, check out the Rennen Rollenlager www.rennendesigngroup.com
    Reputation: jakerollo's Avatar
    Rohloff chain tensioner
    Before my inbred era i used a Rohloff Chain Tensioner. The spring is strong and it ensures that the chain grabs on a large part of the cog. I can recommend it.
  1. 9 Speed Hub question...
    By hord in forum Wheels and Tires
    Last Post: 04-28-2004, 07:13 AM
  2. 8 speed vs. 9 speed spacing (where is it)
    By Island Ruffian in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2004, 08:49 PM
  3. commuter question: do I need a tool?
    By capt pearl in forum General Discussion
    Last Post: 03-19-2004, 03:36 PM
  4. 9 speed hub with 8 speed cassette
    By Capt_phun in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2004, 11:23 AM
  5. Hope Spot Disc tab facing tool question?
    By ToddM in forum Brake Time
    Last Post: 03-09-2004, 10:07 AM
