Tip for finding chainline- Mtbr.com
Results 1 to 6 of 6
    LET'S GO RIDE BIKES!
    Reputation: robbyracer's Avatar
    Hey all. Just wanted to share this tip I found for determining your chainline.
    Hang your bike by the front wheel then loop the chain over the chainring and use it as a plumbob. It will point right to where your rear cog should go.
    Pretty cool!
    Robb
    Specialized Rockhopper Comp
    Canondale Synapse w/DuraAce goodness
    Reputation: metrotuned's Avatar
    http://www.sheldonbrown.com/chainline.html
    After reading it and going through it, still found that the best way is to get the hub and crank all thrown on the bike with a chain. Then determine "chainline" from trial and error. It worked for me going from a 113bb symmetrical to a 116 right+5 offset bb. I was not able to figure that out from the chainline guide. Some things, as opposed to busting our your math skills and a rule, you just gotta get in there and do it.
    Creative Producer, Will of the Sun, Platform Pedal Shootout 1M+ views WoS
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Only works if your bike hangs plumb .
    Ahhhh. Yeah true. Just sounded like it'd be worth a shot.
    I did the trial and error method but I'll check it with Sheldon's math method. Yuk... math.....
    Robb
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    I bet that would work, I don't see how it wouldn't hang plumb bob. At least it would get it real close, closer than you could with the naked eye.
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
    Do the math. Very easy, why not get it right the first time.
