Ti post Ti frame.... any problems?- Mtbr.com
Results 1 to 3 of 3
    Want to install a Ti post in a Ti frame. Are there any problems doing that? Like will it end up seizing after awhile?
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    grease it up good or use anti-seize
    and remove or at least loosen it every once in awhile and you should be ok.
    Some Ti frames....
    Have an aluminum insert (My dean does) But the advice to use anti-seize is good, follow it and things should be fine.
  1. Replies: 14
    Last Post: 03-31-2004, 10:33 AM
  2. Cracked Ti Frame
    By n8ofire in forum 29er Bikes
    Last Post: 03-26-2004, 11:21 PM
  3. Ti brake studs on a Ti frame?
    By tmaybee in forum Weight Weenies
    Last Post: 03-16-2004, 05:20 AM
  4. Building up a Ti frame, Where should I use ti prep?
    By Old_Bashturd in forum General Discussion
    Last Post: 03-01-2004, 10:52 AM
  5. Seat post problems
    By pots in forum Giant
    Last Post: 02-29-2004, 04:22 AM
