Ti or Al chainring and cog?- Mtbr.com
Results 1 to 9 of 9
    I like mud
    Reputation: Patterson's Avatar
    I'm looking at a Homebrewed set.
    I like the colors I can get with Al but obviously Ti will last me longer.
    Does anybody have any advice, other than aesthetics and price?
    How long can an Al chainring last? I'm leaning towards the aluminum chainring with a matching Ti/Alu cog.
    Would the Alu wear on the chainring cause any issues considering the cog would probably not wear as fast? Is this uneven wear ok?
    I'd imagine that's a tiny issue but don't actually know.
    The Bike Race Database:
    www.meet4rides.com
    Low Rep Count
    Reputation: 1SPD's Avatar
    I don't think it would be a problem having them mis-matched as you mentioned. Worst case is that the chainring starts to wear out and you have to take it off and flip it over! Brand new teeth all over again!
    I personally have two HBC rings that I have been riding for about a year (well the 32 for over a year now) and have no problems what so ever with wear on it. Personally, I don't think I would waste my money on the ti chain ring at this point. The alu one is lighter, cooler color options, can be flipped over and reused, and costs less. How many more pluses do you need?
    You can buy three Al chainrings for the cost of one Ti ring. Guess it just depends if the extra cost is worth it to you. I'm sure the Ti ring wouldn't wear out for a very long time.
    As far as uneven wear, like 1spd said, it shouldn't cause any problems. Think about all the people who are running Al chain rings and steel cogs with no problems, including myself
    Gotta pay to play
    Reputation: michaelscott's Avatar
    I asked myself the same question and decided to go with Al because:
    1) It will last me at least 2,000 miles. Then I'll flip- so I've got at least 5-6 years at my current ride rate.
    2) I'll probably end up buying a new bike before #1 even happens.
    3) The colors make the bike look pleasing.
    I like mud
    Perfect, decision made, thanks.
    www.meet4rides.com
    Low Rep Count
    I am guessing you decided on an alu chainring. Just think, the money you save you can buy some other cool crap!
    Did I catch a niner+?
    I would also be afraid to get a more expensive ring since I like to "gear up" every year or two sometimes out back sometimes up front.
    Quote Originally Posted by Mr Pink57 View Post
    Good point, I'd kick myself if I wanted to change the size of my chain ring after buying a Ti one...
    I like mud
    Quote Originally Posted by 1SPD View Post
    Yes, alu chainring and alu/Ti cog.
    www.meet4rides.com
  1. Calf meet chainring - removing the big chainring from your bike
    By fc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-13-2010, 10:15 AM
  2. Double chainring setup - correct chainring sizes?
    By Transwave in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-26-2009, 04:58 AM
  3. Replies: 18
    Last Post: 02-25-2007, 10:28 AM
  4. Chainring replacement: lube chainring bolts?
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-23-2006, 11:35 AM
  5. Largest recommended middle chainring for a 22T chainring
    By jzt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-18-2005, 05:41 PM
