Thin stamped cogs and ti freehubs- Mtbr.com
Results 1 to 9 of 9
    Jan 2009
    I know that thse thin, stamped steel cogs chew up aluminum freehub bodies, but would it be unsafe to use one on the ti freehub on my Hadley? I just need a 16t cog on my wheel for a gravel race.
    Reputation: Velobike's Avatar
    How much is a replacement Ti freehub? How much is a widebase cog?
    That's your real question.
    Personally I won't put the stamped cogs on even a steel freehub.
    Latitude: 5736' Highlands, Scotland
    Jan 2009
    The issue is that I have a gravel race on Saturday and I don't have time to buy a 16t wide base cog. I cuould use a 38t ring but it's too big to fit on my ROS with the EBB anywhere near its current position. I am trying to avoid screwing up the saddle-BB offset position even more than it already is. So instead of using a 38/20 gear, I'd like to use the 34 I have on there now with a 16t cog. I got the frame last week and Castel Grind is in two days, so I did not have time to think this through.
    I doubt anyone has one in stock locally and my work hours overlap the business hours of every shop in town.
    Then again, 34/16 might force me to rotat the EBB forward anyways, making this question irrelevant because in that case. I might as well use the big ring.
    Good point though, probably not worth the risk to my hub. If I have to screw up my bike fit to do it, hope my knees survive, though.
    Aug 2010
    Any SS buddies in the area who could lend you a cog? FWIW I wouldn't take the risk of a cheap cog eating my freehub.
    Jan 2009
    Nevermind, non-issue. I had read somewhere that a 38t chainring will only clear the yoke on my ROS in the forward position on the EBB. I just tried it and the 38t ring clears the yoke all the way around the EBB. So I'll use one of the wide base cogs I have with the big ring and not worry about it.
    Reputation: joshhan's Avatar
    Mar 2011
    Gravel race on a ROS9 is a more intriguing story!
    Bikes, lots'o bikes
    Jan 2009
    The whole bike is not even a pound heavier than the Soma Juice that I rode on my last 100k gravel race. I don't see what the big deal is.
    Mar 2011
    Well, it's not all about weight. I was picturing you out there with a 140mm fork and 2.4" tires all around.
    Bikes, lots'o bikes
    Jan 2009
    Nah, it's set up as an XC bike already. Narrower tires, 2.0 Thunder Burts and change thegearing from 34/21 to 38/19 or 20. Hydration bladder in a frame bag. TOGS, 120mm Reba. That's "gravel mode." All I have to do is swap the cog, chainring, and tires, really.
    A rigid fork of the appropriate length would be cool, but not worth the $$ for the occasional gravel race.
  1. Who has the quietest freehubs?
    By championp in forum Wheels and Tires
    Last Post: 09-23-2015, 11:33 PM
  2. 40-something T cogs and Freehubs
    By Fleas in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-02-2015, 06:29 PM
  3. Replies: 3
    Last Post: 11-01-2014, 07:31 PM
  4. Exploding XT freehubs...again, and still.
    By Stabone33 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-25-2014, 12:56 PM
  5. Replies: 12
    Last Post: 11-07-2013, 09:36 PM
