TENSIONER vs, NO TENSIONER- Mtbr.com
Results 1 to 11 of 11
    Smile TENSIONER vs, NO TENSIONER
    I Just Converted My Trek 8000 To A Ss By Using A 32t Salsa Ring In The Frt And 18t Bmx Cog On The Rear With An Older Model Surly Singulator. If I Were To Get A 1/2 Link And Loose The Tensioner, Would The Quick Release Skewer Be Sufficient Or Would I Need To Get A Bolt On Axle???
    I Am Running A 6-7 Speed Kmc Chain On The Bike. Should I Be Using A Bmx Chain?
    Thanks......
    Out spokin'
    Dec 1999
    Here's one loser's opinion...
    As much as I hate running a tensioner on my vert-dropout X-Caliber, I like dropping the chain or running it too tight or too loose even less. Personally I'll run the tensioner on any bike that lacks any other form of chain tension adjustment.
    If you're running vertical dropouts, it's fine to run a QR in any case.
    Personally, I use the narrowest chain I can fit on the cog/ring. Although BMX chains weigh more, thereby giving the impression that they're stronger, I've come to believe that a standard multi-speed chain (no matter 6/7/8/9-speed) is easily up to the task of singlespeeding. I do have dedicated 1/8" rings and cogs and have used BMX chains (high quality like Sram PC-7x). I also own narrow rings/cogs with which I utilize an 8-spd chain. I've never broken either type of chain. But I believe that the better the width of the chain matches the width of the cog/ring, the better overall performance.
    I do know of one fellow (the legendary General Coonskins) who split the pin rollers on his PC-7x chain radially from using a narrow cog with the wide chain.
    --Sparty
    Quote Originally Posted by erkstone
    Thanks......
    disciplesofdirt.org
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    I'm running a Salsa 34t, Novatech 18t cog, PC99 Hollowpin chain with a half link and no tensioner, so far so good.
    No problems with the QR's so far, I'm using SRAM hubs with SRAM QRs.
    Reputation: ernesto_from_Wisconsin's Avatar
    TENSIONER vs ENO
    ENo will make you happier. Eccentric hub = perfect tension every time.
    Quote Originally Posted by ernesto_from_Wisconsin
    .........ENo = No disc brakes -------> not for me
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    what I have found
    A half link still will not give you proper tension.
    a quick release will hold just fine.
    My experience with chains: shimanos suck all others are fine,singlespeeding puts less stress on chains because of the straight chainline.
    If you are handy with a file or dremel there are a few things you could do.
    check Sheldon Brown's site for some info on this.
    An ENO is an enormous waste of money.
    I've been inside too long.
    Reputation: MellowCat's Avatar
    Have you looked at Discos?
    http://offcamber.com/directions.html
    Fett and a few others run this setup, seems to work great and its cheap!
    Thanks......
    ENO is not a waste
    Quote Originally Posted by KgB
    No way, I disagree. ENOs are a cure for tensioning headaches. Before I found out about the ENO hub, I asked Waterford if they could install an EBB shell on my Gunnar Rockhound. They told me the frame was going to be stripped, cut, welded, repainted = $400, the same price I paid for the frame, at cost. Then one day I found out about ENO and just ordered one from WebCyclery....it was better than a grilled cheese sandwich...The rest is history with White Ind. Sarah n' me have done web updates, ads, etc., and soon, the whole website will be new, thanks to me. The price justifies the manufacture of the high end hubs. I would never say that a hanging tensioner is a waste of $$$, just a way of testing SS, and if one likes their Trek or Yeti ht frame enough not to get a new frame, then ENO is the answer.
    In a few months, the eccentric ENO will have versions. That's all I am saying.
    "We're only making plans for Nigel...auuuuuuuuuuu"
    Out spokin'
    Dec 1999
    Please help me understand
    KgB, what makes you say this? I am curious because I am considering the purchse of an eccentric ENO for my CoMotion -- it would make a fantastic SS.
    Thanks.
    --Sparty
    disciplesofdirt.org
    KgB
    KgB is offline
    SNGLSPD
    Just like AOL
    KgB, what makes you say this? I am curious because I am considering the purchse of an eccentric ENO for my CoMotion -- it would make a fantastic --Sparty
    Sometimes I'm afraid to check my mail because I know those bast@rds at AOL are going to send me another CD or promotion.
    That's what i'm feeling here.
    flaccid member
    Reputation: retch's Avatar
    no tensioner for me...
    I filed the dropouts on my steel frame so I wouldn't have to run a tensioner. That way I can ride cross country (literally) through grass fields and have one less thing for salad to hang onto. I also enjoy the sound of small sticks that would probably screw up a tensioner get chewed up & spit out by my tensioner-free setup. The derailleur I used for a tensioner was pretty darn noisy too, but I'm not sure if "real" tensioners have that problem.
    Who's really holding the remote control?
  1. Replies: 8
    Last Post: 03-05-2004, 04:13 PM
  2. Need help with new cranks/chainguide or tensioner system
    By DownHillFast in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-04-2004, 02:22 PM
  3. Determining if I can go sans tensioner?
    By seely in forum Singlespeed
    Last Post: 02-07-2004, 10:19 AM
  4. rennen tensioner ?
    By dirt diggler in forum Singlespeed
    Last Post: 02-04-2004, 12:18 PM
  5. 425mm chainstays and no tensioner?
    By Timber in forum Singlespeed
    Last Post: 01-31-2004, 07:31 AM
