Tensioner- Mtbr.com
Results 1 to 16 of 16
Thread: Tensioner
    Dec 2004
    Tensioner
    Looking to try out singlespeeding but as i've got vertical dropouts i'll be needing a tensioner, being a bit vein whats the best looking tensioner?
    Try to get one that is push up, they give a cleaner appearance.
    Reputation: rob1035's Avatar
    I've had great success with the Rennen tensioner, its a really nice unit.
    Reputation: stevereeneo's Avatar
    The DMR Simple Tension Seeker (STS) works very well... basically the same idea as the Rennen.
    "You know how they make aluminum bike frames? They take steel and suck out all the soul..."
    Reputation: combatkimura's Avatar
    Yeah, rennen rollenlager is going to combine the best performance and looks of the bunch. Surly singleator looks really great but is spring loaded which isn't the greatest.
    Although this one that attaches to the bottom bracket is really cool.
    Rennen
    Full Tilt Boogie
    May 2005
    I like the Soulcraft Convert. It works like the Rennen in some ways, but has a quick release lever on the bottom. This makes wheel or tire changes virtually as easy as with a normal vertical dropout, yet works just as well as a Rennen in other capacities. I've used all types of SS frames and tensioners. I've settled on this solution as the best and easiest solution for me.
    I sell bikes here. Check out the Blog here. Facebook.
    Mar 2006
    Quote Originally Posted by benwitt11
    I second the Soulcraft Convert. I have used one for a couple years on my Trek 9.8 and never had any problems with it, and as it was mentioned, has a lever to release the spring tension to change out the wheel quickly and easily...
    Reputation: cstem's Avatar
    +3 on the soulcraft. I used mine in harsh conditions, never did a bit of maint. and the only problem is the pin that releases it for tire change has fallen out requiring a small pointy tool to release it. That has supposedly been fixed by the manuf. in recent years. It's now on my SS commuter which sees rare flats so no big deal. I have not used any others, but would buy one again if I needed one.
    Vassago Cycles, Shadetree Bikes, Flat Tire Bikes, Galfer Brakes USA
    hardtails rule!!!
    My Surly Singleator has worked good. No chain jumping off on the trail.
    Nov 2007
    Melvin
    I have yet to make my melvin fail, it may not be the best looking thing out there, but it's bullet proof.
    http://www.paulcomp.com/
    i've heard that you can run a front mech with this set-up, not that this is appropriate for this thread.
    Satellite Jockey
    Reputation: mantraman's Avatar
    Good job! Yess ETR-V
    I'm new to SS but have great success with the ETR-V by yess
    http://shop.yesspro.com/products/etr-v
    Really fast shipping and these guys have been around in BMX a loooong time!
    Easy setup and I like the fact it has a fixed primary arm and it stays protected.
    Yes it is a push-up type.
    Pic here....
    http://www.flickr.com/photo_zoom.gne...57603441318364
    WORK TO LIVE DON'T JUST LIVE TO WORK!!!!
    The melvin is beautiful and probably the best made tensioner out there, but I still feel that the solid mounted units (non-spring loaded) perform better and look cleaner. However, without a spring the tensioner cannot adjust to variances in chain tension due to out of round or imperfectly mounted chainrings.
    Quote Originally Posted by combatkimura
    Wouldn't a non-spring unit adjust just as well as sliding dropout?
    Absolutely, just as you would with a sliding dropout you must make sure the chain tension is good at all points of the crank rotation.
    US Army Vet-Airborne 11B
    Reputation: longhaultrucker's Avatar
    i broke my origonal surly singleater (as in,the older designed one).seems to me the non-spring loaded ones would last longer tho.ya could use yer derailluer to keep the chain tight till ya decides if'n ya likes SS'n.not the classiest way,but free and no waiting.
    by the way....welcome to SS'n!!!
    have fun.
    steve
    '11 Origin 8 700CX
    '14 Surly Troll
