Switching between SS and IGH, brilliant solution or doomed to fail?- Mtbr.com
Results 1 to 12 of 12
    !Vamos, flaco!
    Reputation: Pabs's Avatar
    I think the title says it all. I prefer riding SS but woulld like to have gears for some rides on those rare occasions or trips when I'm with other non-SS riders. I'd rather just have one bike.
    Is is feasible to have an internal geared hub wheel that I can quickly swap onto by SS?
    "Fact is only what you believe; fact and fiction work as a team." Jack Johnson
    one chain loop
    Reputation: fishcreek's Avatar
    don't shift?
    everything sucks but my vacuum cleaner.
    !Vamos, flaco!
    Quote Originally Posted by fishcreek View Post
    don't shift?
    It's not the same, man.
    more skier than biker
    Nov 2006
    Quote Originally Posted by Pabs View Post
    What is the problem in riding SS with other non-SS riders?
    Kappius Components Ambassador - Ping me a note for a discount code
    !Vamos, flaco!
    Quote Originally Posted by Tyrone Shoelaces View Post
    I think we're missing the point here. But anyway, generally it's not a problem, but on occasion, from time to time on certain rides, and I know it's sacreligious, I'd like some gears and I'm wondering if an IGH is a solution.
    I think you're over-complicating the issue. The cheaper and simpler route would be just to get a second rear wheel with a cassette (or if you're like me with a 9-sp hub on all my singlespeeds, just an extra cassette), derailleur, and shifter. The swap seriously takes me 15 min. Cost is minimal.
    Reputation: gjenkins@'s Avatar
    Wheel and tire switches are a pain. Time for a new bike.
    !Vamos, flaco!
    Quote Originally Posted by p nut View Post
    I did that when I've previously switched from SS to a 1x9; it took me more than 15 minutes ... how do you do it?
    Don't you have to take off the grips (or one of them)?
    Either air compressor or alcohol to take off grip. Pretty quick job. Then, bolt on the derailleur, cables zip tied, powerlink chain then cassette installed.
    I would like to find a way to avoid taking off the grips. I wish I could find a decent shifter with clamshell clamps.
    !Vamos, flaco!
    Bummer. That's what I was hoping for.
    Jan 2009
    if you have a read hub with room for a cassette and a RD hanger, it would be easy. here's what I plan to do with my Karate Monkey, which is set up as a single-speed at the moment:
    700c hybrid tires
    long der cable
    short-cage RD
    8-speed cassette
    8-speed shifter
    separate chain cut the length for that cassette
    I have Ergon grips, so the grip comes off easily to install the shifter. keep the shifter and RD connected by a cable cut to length for the frame. swap the tires, swap the SS cog for a cassette, install the shifter and RD, swap the chain and bam, 1x8 bike for pavement excursions.
    if you dont have a RD hanger and no where to put a cassette, the IGH rear wheel with a tire already installed on it and a bolt-on grip would be the way to go. no need for a longer chain, rear mech, or tricky parts swaps.
    that's that
    Get these:
    Paul Component Engineering
    Just leave the lever and the rear der all cabled up, just take them all off @ the same time.
    Use quicklinks on the ss chain and the der chain.
    If the switch between gears and ss takes more than 5 minutes, you're just taking your time.
  1. We're DOOMED!
    By bing! in forum The ReCycle Bin
    Last Post: 09-07-2010, 06:26 PM
  2. ...doomed, DOOMED!
    By Natalie Portman in forum General Discussion
    Last Post: 01-23-2008, 01:16 AM
  3. Is Bittersweet doomed?
    By Big Jim Mac in forum Great Plains - OK, KS, NE, SD, ND
    Last Post: 10-21-2007, 08:54 AM
  4. Are we doomed to be downhilers?
    By GreenBonty in forum Yeti
    Last Post: 05-28-2007, 10:19 PM
