Switching between SS and 1X11 / Can I use 9spd and 11spd chains?- Mtbr.com
    Aug 2010
    I usually run SS but occasionally want to make it a 1X11.
    I usually run the cheaper 8 or 9 speed chains for SS. The Shimano drivetrain will require the more expensive 11-speed chain. I'll be running a narrow wide chainring, most likely a Wolftooth.
    Can I run the 8/9 chains when SS and the 11 speed chain when geared without causing any weird wear patterns on the chainring and chains?
    Would be nice to save a few bucks on chains by only having to run the 11 speed chain when geared.
    Just Joshin' ya!
    Reputation: PrincipalRider's Avatar
    Jun 2005
    Quote Originally Posted by racefit View Post
    I am not a metals or chainring expert, but as long as both chains fit the chainring, which they should, I don't see why this would wear down the chainring teeth or cause any issues to the chains. I have run different chains on the same chainring, switched back to the other chain, and never had any issues.
    Getting a dropper post is like getting a bidet. I didn't know I needed one until I get one and boy, does my ass thank me.
    WillWorkForTrail
    Jun 2012
    As long as there isn't any excessive wear on the ring it should work fine.
    Reputation: ancient rascal's Avatar
    I would like to do the same with a new build. What bike are you doing this with? I have a worn out Lynskey Ti SS and I'm looking for a lightweight geared 1x10/11 rigid that I can also use as a replacement for the Lynskey. Looks like your question was answered eh? PS I really would prefer sliders on it also if possible but that may put too many limitations.
    Suicide by single speed. Work in progress.
  1. 1x11, Hubs & Chains
    By fellsbiker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-11-2015, 10:55 PM
  2. 11spd PowerLink on a 9spd chain?
    By grundy in forum Singlespeed
    Last Post: 07-13-2015, 03:06 PM
  3. What chains are you running on 1x11?
    By blantonator in forum SRAM
    Last Post: 06-04-2015, 02:25 PM
  4. kmc chains and 1x11
    By ry24000 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-14-2013, 07:46 AM
  5. Confirmed 10spd chains more durable than their 9spd counterparts.
    By customfab in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2013, 05:04 PM
