Swapping chainring/cog setups and chain length- Mtbr.com
Results 1 to 5 of 5
    Combat Wombat
    Reputation: BrianU's Avatar
    I have a 2008 16" Jabberwocky that I have run with a 34/20 for most of the time I have owned it and used a half-link to get the axle pretty close to the middle of the horizontal dropouts. Take the half-link out and depending on if you add or shorten the chain, it puts the axle at extreme ends of the dropouts. Recently a different job has put me in a location where hitting a LBS is now convenient. I like the idea of just grabbing a chain when I need it, along with helping out a good LBS. This has also had me considering ditching the half-link. Just one less thing I don't want to mess with. I used this website to calculate chain lengths.
    http://eehouse.org/fixin/index.php
    From what I can tell, switching to a 32/19 setup would put me real close to what I currently run, only add .13" to the length, and ditch the half-link. Is anyone familiar with this website and if so, does it look like I am figuring this correctly? I would also appreciate any first hand experience with running a 32t chain ring on a 16" Jabberwocky frame and what has worked for you.
    Reputation: AlexCuse's Avatar
    The calculator on that website works pretty well, long as you know the numbers to put in it.
    Anecdotally speaking, I went from 34-20 to 32-19 on my bike last year sometime. With 34-20 the axle was in the middle of the dropouts and changing it put the wheel way toward the back end. Removing a link got it right where I like it. So it seems like you are probably on the right track.
    Yeah I only carry cans cause I'm a weight weenie.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    That is a great calculator.
    I run multiple single speeds and depending on what isn't in use requires considering other chainring/cog combinations.
    For a single rig/cog combo calculator, this is my goto one...
    http://software.bareknucklebrigade.c...it.applet.html
    【ツ】 eDub 【ツ】
    Combat Wombat
    Thanks for the information!
    Always in the wrong gear
    Reputation: Impetus's Avatar
    Aug 2014
    32/22 on a 16 Jabber puts the sliders about 3mm from full forward slam.
    32/19 is about 1/3 of the way back from forward, IIRC.
    I got a WolfTooth stainless 19T cog on the Scratch-n-dent, mounted it just to see it fit and took it back off for an upcoming steep/tech ride. I'm away on business until Friday, but can check if needed then.
  1. Chain jumping from small chainring to middle chainring
    By menusk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2013, 10:31 PM
  2. Swapping gears, horizontal dropouts and chain length
    By BigTex91 in forum Singlespeed
    Last Post: 04-10-2012, 06:35 PM
  3. Replies: 6
    Last Post: 03-27-2012, 12:17 PM
  4. Swapping out torx chainring bolts for hex?
    By 6thElement in forum Shimano
    Last Post: 04-29-2011, 05:46 AM
  5. Swapping frames - 68 to 73 bottom bracket - spindle length?
    By marpilli in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-22-2011, 11:12 AM
