susp fork for SS project....suggestions plz!- Mtbr.com
    Reputation: cajonezzz's Avatar
    I'm turning an old Stumpjumper into my first SS and would like to replace the blown out Specialized susp fork (looks like an old mag 21 type) with something newish. Even used but rebuildable would be cool...
    I think short travel, 80mm or so would be fine for this frame, I'd like to spend less than 200 bucks.
    any suggestions on what to look for?
    thanks...
    craig
    Reputation: logbiter's Avatar
    my vote goes for a 'zoke Z2- the '97-99's have been going on ebay for around $100. the '98/99 atom bombs are 70mm travel and have shortest axle-crown (vs the bam model, which has a bit more travel) if you've got an older stumpy, or go for a '97 which is ~65mm travel.
    If the bushings are sloppy, marzocchi will rebuild the fork for about $70 with a fast turnaround.
    What yr stumpy and 1 or 1 1/8" headset? steel or M2? I had a '96 M2 with a '98 a-bomb. Sold the stumpy to finance a FS, and now that fork is now on my SS converted Norco TNT.
    hasta,
    Serge
    Quote Originally Posted by cajonezzz
    thanks...
    craig
    Back of the pack fat guy
    '04 Marzocchi MX Comp
    thanks...
    craig
    I just bought a 2004 Marzocchi MX Comp air/coil/oil fork from jensonusa.com for $179. (Stupid me, I should have waited - my LBS sold the same fork this past weekend for $85!!.) Anyway, this fork has 85mm of travel, measures 458mm from axle to crown, and has internally adjustable rebound dampening. It's a traditional coil/oil Zoke design (like my old Z2 Atom 80), but it has air assist for preload. It's not the smoothest fork, and I had to dump a serious amount of oil out of it to get even 80mm of travel, but now that I have it dialed in, it works pretty well for a sub-$200 fork and really improved the handling of my 1x1.
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    Quote Originally Posted by logbiter
    Z2 is a solid choice. I use newer 2000 and 2002 versions on my SSs.
  1. Kona Project 2 rigid fork
    By Eltbee in forum Singlespeed
    Last Post: 07-12-2015, 08:53 AM
  2. 5" Salty or X5: fork suggestions?
    By chiho in forum Ventana
    Last Post: 08-29-2004, 06:13 PM
  3. 5" Ventana X5/Saltamontes fork suggestions?
    By chiho in forum Shocks and Suspension
    Last Post: 06-03-2004, 05:55 PM
  4. My next project, help with a fork
    By DirtDad in forum Vintage, Retro, Classic
    Last Post: 04-15-2004, 09:19 AM
  5. My next project - Help with a fork
    By DirtDad in forum Singlespeed
    Last Post: 04-15-2004, 04:03 AM
