Surly tugnut alternative- Mtbr.com
Results 1 to 17 of 17
    Single-Speed Gangsta
    Reputation: RoLLinFaTTies's Avatar
    hey guys,
    i really liked using the Surly tugnut for tension, but the bolt on the ChrisKing SS hub is too big for the tugnut. Before i whip out the drill. any of you guys using anything else ?
    Reputation: ernesto_from_Wisconsin's Avatar
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by RoLLinFaTTies
    hey guys,
    I drilled out a Spot Rocket tensioner to work with the CK SS hub, but I like the single bolt systems like the Redline ones better (as Ernie mentioned.)
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    I have a set of the redlines @ home that i need to return. The CK bolts are too big for those too
    Good luck finding one that fits. I've tried a handful with the Fun Bolts and haven't found one that works without enlarging the hole.
    The Redline ones are good. I've got a few sets of the Sinz ones as well.
    Reputation: xdefx's Avatar
    I've been using these....pretty light, adds a little bling....
    http://www.danscomp.com/440006.php?cat=PARTS
    can you change the bolts?
    Quote Originally Posted by bnelson
    On the CK SS Hub? Not to something with smaller diameter threads; it wouldn't fit properly into the hub.
    Quote Originally Posted by Drevil
    Thats what i figured. Time to get creative. Sheesh with the bigger bolts youd think CK would make such tensioner . Anyways thanks for the help.
    Poorly Disguised Poser
    Reputation: unit's Avatar
    Are a lot of you guys really having problems with them slipping?
    I always figured that the reason King does not make such a tensioner, was because it was not necessary. I know a lot of *really* powerful guys (and some serious clydes) that run these and never experience any problems with slippage.
    My ego is bigger and better looking than yours.
    Quote Originally Posted by unit
    Yup. I've used the hub for at least 4-5 years on two titanium frames, and the serrations on the steel axle-end has smashed down so it no longer bites into the frame.
    I was just about to put in an order for a new axle because I strongly dislike using chaintugs unless absolutely necessary.
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    only way to use any tug with ck funbolts is to enlarge the hole.
    however, if you are going to use tugs might i suggest an alternative?
    get the qr conversion kit from ck (a good excuse to get a set of salsa qr's) and then use the surly tuggnut and qr washer. zero slipping and tool free wheel removal.
    "Knowledge is good." ~ Emil Faber
    ohhhhhhh
    I never considered the possibility of the hub seeing damage (knurling flattened) from a harder material.
    That does suck indeed. OTOH, King tensioners (if they existed) would probably be on par (price-wise) with a new axle (which would probably be King's recommended fix).
    Thanks for enlightening me.
    i have to adjust them before pretty much every ride.
    Quote Originally Posted by monogod
    good idea !
    trail rat
    Reputation: slocaus's Avatar
    Hows about an olde sckool church key?
    Oh!!! T e n s i o n e r, ahhhhhhh!
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
