Surly 1X1 Fork Q's- Mtbr.com
Results 1 to 8 of 8
    Its too warm here....
    Reputation: SenorPedro's Avatar
    Surly 1X1 Fork Q's
    For all you rigid runners, specifically those with the Surly 1X1 fork, I have some questions.
    Is it susp. corrected for a 4" or 3" fork? About how much does it weigh? Do you like the way it rides? Does it have good tire clearance?
    Thanks for your answers, and if anyone has input on the Kona Project 2 I would appreciate it also.
    Thanks,
    Pete
    "Speak softly and carry a big stick." T.R. Roosevelt
    Reputation: TrevorInSoCal's Avatar
    Quote Originally Posted by SenorPedro
    IIRC it's corrected for a 3" fork. Not sure about weight, never had it off the bike. I'm sure you could email Surly, or perhaps even find weight specs on the site. It rides like bike. I've had no problems. Haven't tried to put anything larger than a 2.4 in there, but judging by the clearance on that, you could fit a pretty big tire in there.
    -Trevor
    King Pin
    Reputation: xrmattaz's Avatar
    Smile
    I run the Surly rigid fork on my high dollar bling bling titanium SS....I trust it that much.
    I've broken many lighter weight steel forks, including MANY lightweight expensive ones.
    I like that big 'ol heavy Surly fork. A 2.5" WTB Weirwolf fits with room to spare....
    Just my $.02.
    Master of the Obvious
    Reputation: Angus's Avatar
    How do you like your King?
    Quote Originally Posted by xrmattaz
    Just my $.02.
    just wondering how you like your Sofa King?
    formerly Giantxc
    Reputation: MrXC's Avatar
    P-2
    I've been riding the P-2 for about 2 years now (although its about to be replaced with a new Spicer ti disc!) and I've been nothing but pleased with it. It fits a 2.4 Mutano Raptor and the taller Geax Blade 225 with ease. Point an click accuracy and definitely a rigid fork (didn't notice any flex). Weight about 2 lbs. Suspension corrected at 410 mm (less than 80 mm).
    King Pin
    ... and if we just ...
    I have ridden and owned many many dozens of bicycles in the past few decades.
    I must say...the Sofa King Ti King Pin tops 'em all. Really. Lightweight, stiff yet compliant with beautiful weldage. She will certainly be buried with me.
    I have zero issues with this frame.
    Quote Originally Posted by Angus
    like my Surly 1x1 fork alot
    email Surly with questions and they get right back to you. Corrected to 80mm. I replaced my Judy T2 80 mm with it. Comes ready to install. Just make sure there is no paint on the race seat. I have a Maxxis Mobster 2.7 inch up front. It is actually 2.5 inches wide and there is lots of clearance. On Surly's web site, the specs for the 1x1 frame say the fork is 421mm axel to crown. This is a mistake according to Surly. The fork is 413mm axel to crown.
    If you run a FAT DH tire like the Maxxis then your front wheel diameter will be around 27 inches. The bigger wheel plus the 413mm Surly 1x1 will be about the same length as a sagged 80mm fork with a 26 inch diameter wheel. This is the case with my set up. Therefore no change in head tube angle from making the switch.
    A bit of lbs advice. Don't by a rigid fork with a disk brake mount if the mount is welded on one side only. This is a much weaker construction than a mount which is welded on both sides. The Surly 1x1 brake mount is welded on both sides.
    One gear to rule them all
    Reputation: 32seventeen's Avatar
    Surly spec
    Surly says there fork has room for a 2.7 tire. Canti /V model weight 1030grams, and disc model weight 1058grams. Hope that helps.
    Thanks,
    Pete
  1. Feeling Inventive? The electric suspension fork
    By old_dude in forum General Discussion
    Last Post: 01-18-2012, 04:07 PM
  2. Help me Tune my 04' TALAS RLC Fork
    By 2tricky in forum Shocks and Suspension
    Last Post: 07-03-2004, 11:08 AM
  3. Lets start a debate, best fork? worst fork? best make?
    By Domdil in forum Shocks and Suspension
    Last Post: 02-26-2004, 09:53 PM
  4. Replace Manatou Black fork with?
    By Thumbie in forum General Discussion
    Last Post: 02-16-2004, 10:30 AM
  5. Surly 1x1 Suspension fork question
    By madonenm in forum Singlespeed
    Last Post: 01-28-2004, 07:43 PM
