Super sized single speed cogs- Mtbr.com
Results 1 to 12 of 12
    Feb 2014
    Is there anybody that makes a really big ss cog? Like 30+?
    Before I'm berated for being a *****, I do have an idea I'd like to try. I currently spend a lot of time climbing in my 22x36 combo. A dingle set up with 22/36 front and 36/22 rear would be the cats pajamas IMO.
    Just wondering if it's even doable.
    Thanks.
    Low speed, High Drag
    Reputation: kevhogaz's Avatar
    I'm sure you get creative with a cassette, and build something like that. Probably not a lot of market for a cog bigger than 22t.
    I need a cool saying to put here.
    Aug 2014
    The largest Endless makes is 25t. That is probably the biggest you can get. Thinking if Endless does not make a larger you are out of luck.
    '15 Niner Jet 9 Carbon
    '19 Karate Monkey
    Motobecane Boris
    Raleigh Willard 3, Furley & Militis 3 (SS)
    Nashbar Carbon Road
    Feb 2014
    Figured as much but it never hurts to ask.
    Actually considered pulling a cassette apart. My concern would be digging into the freehub unless I could maybe find something with a carrier that would work...
    Reputation: Velobike's Avatar
    I had the same problem and did not want to use a cog from a cassette because that guarantees the chain will come off.
    I found an adapter. It's actually intended for Pinion bottom bracket gearbox bikes. To keep them light they do the torque multiplication at the rear end, so they need a large rear cog.
    The adapter takes a normal 4 bolt chainring.
    I needed it so I could have a singlespeed ratio for deep snow or when I'm bog hopping.
    My standard trail ratio on my fatbike is 32/22, and for my ultra low I run a granny ring of 22 and a rear chainring of 32. Thus I can change over and because the chain length need remains the same, I don't have to readjust the disk calliper position.
    Adapter is available on eBay Pinion Spider Hinterrad - Spider Rear Wheel - P8200 | eBay
    Latitude: 5736' Highlands, Scotland
    I tried using a cassette cog but found it would fold and crack. I had to poprivet a smaller cog to the large cog to reinforce it.
    Feb 2014
    Velo, dude that is exactly what I'm looking for. Awesome!
    Feb 2014
    Just bought one. Bcd looks like 104?
    Did you have to do anything funky with your chainline? And can you change cogs without loosening the rear wheel?
    Thanks so much!
    Quote Originally Posted by Shinkers View Post
    Thanks so much!
    Yes, 104mm.
    The rear wheel would have to come off to remove/replace the cog. Nothing to stop you putting 2 cogs on it though - it's just like putting them on a crank - so if you want to play around with ratios it will be a bit easier.
    Feb 2014
    Sorry, I worded that poorly.
    I mean, can you push the chain over from the 22/32 to the 32/22 without loosening the rear wheel?
    Feb 2014
    Okay a few more questions now...
    So I'm committed to doing this. I had originally intended to get Surly's sliding MDS dropouts to make this easy, but Surly's kind of in the tank right now as far as parts availability goes and probably won't have those for quite some time.
    So I'm considering using an old road derailleur I have as a tensioner, and using the tension adjuster to switch between cogs in the back. This would be super easy to do with the head end of a piece of shift cable pulled into the cable stop and maybe a ferrule.
    My question is, the derailleur had a capacity of a 28t cog back in the day. If I run my chain relatively tight, can I still clear that 36t in the rear?
    And Velobike, what ring are you using on the back?
    ...And Velobike, what ring are you using on the back?..
    Ah, sorry I missed this earlier.
    The chainring I'm using is a stainless steel On-One ring, but Surly also make stainless chainrings.
    My setup is not intended to provide quick gear changes, I have to slacken the wheel and move the chain over by hand.
  1. Work to Bike Month - Super Sized!
    By WSUPolar in forum Fat bikes
    Last Post: 05-03-2015, 12:39 AM
  2. chris king single cogs to build a cassette for hope trials evo 2 single speed hub
    By timsmcm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-22-2014, 05:24 AM
  3. Replies: 14
    Last Post: 03-27-2012, 07:51 PM
  4. really light Ritchey Logic Prestige Super Tubing for single speed
    By royta in forum Vintage, Retro, Classic
    Last Post: 03-27-2012, 02:26 PM
  5. Replies: 0
    Last Post: 03-24-2012, 12:52 PM
