Is this a stupid Idea?- Mtbr.com
Results 1 to 8 of 8
    No Justice = No Peace
    Reputation: Lutarious's Avatar
    Feb 2005
    I am set to buy a custom steel SS. I am deciding between Curtlo, Ground-Up, and DeSalvo.
    I want Disc brakes, and I do not want EBB.
    Am I crazy to build a custom SS with a tensioner? rennen seems so cool, and so easy to use. Why not? What options do I have?
    "Welcome to my underground lair...."
    Full Tilt Boogie
    May 2005
    An ENO ecc hub would seemto be the perfect solution for you. I would be a little leary about building a frame essentially around a hub, but I know people have done it and loved it. Go with whatever you'd think would work, but that's one option.
    paintbucket
    Reputation: wooglin's Avatar
    GroundUp makes a very nice sliding dropout set up. I'm sure both other builders could also use sliding d/os.
    <img src ="https://gallery.groundupdesigns.com/albums/album05/P1010004.sized.jpg">
    When the going gets weird its bedtime.
    Reputation: ernesto_from_Wisconsin's Avatar
    Quote Originally Posted by Lutarious
    you can use discs on horizontal drops, so you know.
    Reputation: thadthetroll's Avatar
    Paragon machine works
    makes sliding drop-outs that any one can buy. Tell your builder you want to use paragon drop-outs for disc brakes and they should fix you up. If they say they cant use them then you may want to look at another builder...
    the "ground-up" that wooglin showed looks like Paragon`s drop-outs..
    Sure you COULD use a tensioner, but it pretty much just hangs there waiting to get snagged off, leaving you walking. I'm in the same boat, trying to figure out if my next SS gets a rear disc or not. I may go for a Vbrake rear and a disc front, just to make things simpler. Just out of curiosity, why do you reject the eccentric BB? Are they problematic?
    Reputation: sean350's Avatar
    Curtlo will build with Rohloff Sliding Dropouts
    I've talked with Doug about building a frame with the Paragon sliding dropouts, and he recommended the Rohloffs. I dig 'em, definitely wouldn't go the tensioner route.
    -Sean
    17.5" pistons of love
    Jun 2005
    Quote Originally Posted by thadthetroll
    I second this. My next choice would be the ebb, but if you've had bad luck with them, I'd do the sliding dropouts. Seems like a killer solution.
    The Domesticated SSer
  1. Good idea or bad idea ...?
    By VIA in forum Downhill - Freeride
    Last Post: 03-06-2005, 08:41 PM
  2. Turner gathering idea
    By DGC in forum Turner
    Last Post: 10-28-2004, 07:23 PM
  3. stupid stupid stupid question, but i still need help
    By jonwebah in forum General Discussion
    Last Post: 06-29-2004, 11:24 AM
  4. Stupid, Stupid, Stupid (OT)
    By gofarther in forum Riding Passion
    Last Post: 04-01-2004, 08:01 AM
