Strength of Surly SS stainless ring- Mtbr.com
Results 1 to 28 of 28
    Reputation: poff's Avatar
    So, I am enjoying my ride in the Cameron Park in Waco, TX climbing on my 29er SS and WHACK!!!! In horror I look down and that is what I see. I check the bolts before every ride too!!!! These are steel and supposed to last. My CBs are steel too! The funny part is that I am standing there looking at all these mess and this guy on road ss is passing by and offers his help. And, of course, he is an mtbr member. Thanks!!!!!
    Dec 2005
    Did one of the chainring bolts break?
    That's puzzling.
    Reputation: bd.sahib's Avatar
    Aug 2005
    Cb
    Quote Originally Posted by poff
    Hard to taco it without popping a chainring bolt first.
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    Boy do I ever love those four bolt spiders.........
    Reputation: Bullit_cn's Avatar
    How many teeth is that? Would you mind asking
    When trails gets tougher, Just stand up and deliver.
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    looks like a bolt loostened from the way it bent. When you checked the bolts, did you have the chainring bolt holder on the back?
    These are steel bolts which I have tightened before the ride. 34t ring. What can I say, possibly two of the bolts broke?
    Reputation: PeanutButterBreath's Avatar
    The chainring bolts could have been weakend from being overtightened and sheared.
    Reputation: Cygnus's Avatar
    4 v. 5
    makes me wonder about the strength of a 4 bolt system versus 5. 4 bolts puts one bolt directly across from another. they don't frequently blow up like this, right? but...starfish have 5 arms for a reason.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Cygnus
    Agreed. 4-bolt/arm has never seemed like a good idea to me.
    mtbtires.com
    Dec 1998
    Quote Originally Posted by PeanutButterBreath
    I used to regularly pop the heads off of steel chainring bolts on 5 and six arm cranks. Had to replace about one a month.
    mtbtires.com
    dirty hippy mountainbiker
    Reputation: wolfy's Avatar
    Dec 2004
    Help?
    How did he help? Was his name Neo, and did he convinced you that there was no chainring?
    -M
    Mike Henderson, Dirty Hippy Mountain Biker and part owner of Jet Lites.
    Reputation: badlander's Avatar
    Feb 2005
    Had a similiar incident
    about 3 weeks ago, popped 1 chainbolt going over a log pile (didn't recognize it for what it was at the time) and started to have problems immediately. My chain started to come off in transitions between the going down and starting uphill. Finally, when I saw what was going on, it was too late. I have an egg-shaped Surly 104 x 32T. One other bolt was loose at the time, either it started to loosen up after the first one popped, or it started to loosen due to the issue stated below. The other two bolts were damn tight.
    Since Surly's are not in stock, I had to put an aluminum Blackspire on it. I was using SS chainring bolts, but went to full size with a washer. After examination I could see that there was too little engagement between the SS chainring bolts and the crank on the body of the bolts. So it goes.
    BTW, having a failure that way is a feature of the Surly. It is now coffee-table art.
    Rick
    "Oh, and how dare you accuse me of lying, drinking, getting high" DessertRagged
    Reputation: edemtbs's Avatar
    Apr 2005
    Quote Originally Posted by shiggy
    Gulp! And here I am building up a brand new ss with a 4-bolt XT crank.
    I've had no issues at all with my current XT setup and I am often not gentle on the pedals. I'd never heard of this issue before. But those pics and stories are scary and are making me think....
    Would a chainring protector ( I've always had one ) help to prevent this? Maybe not if the bolt actually shears, especially on the inside.
    Ed E
    I did have chain guide on and bolts were full length.
    Apr 2005
    Ok then. Well, since I already have the new crank I won't overtighten, I'll keep an eye out for loose bolts and pray a little.
    Thanks -
    Ed E
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    must be the bionic implants.
    or busted crankbolts.
    just curious: what do you think would have been the outcome with a aluminum chainring?
    Only boring people get bored.
    no fat chicks
    Reputation: iliketoridebikes's Avatar
    so did the people at surly already deny your request for a free chainring
    or are they now going to deny it since you had to go trashing them on the big bad internet
    btw it's good that you showed us three pictures just in case we couldn't tell what happened from the first one
    #1 NORBA elite singlespeed racer 30-34 age group
    Apr 2005
    Quote Originally Posted by iliketoridebikes
    Yeah, the title might be harsh on Surly but I don't think anyone who read through this thread took away bad feelings about Surly rings. Sheared bolts, 4-arm cranks (maybe?) and over-zealous tightening of said bolts are possible culprits.
    I am getting the Surly 4-bolt, 34 tooth ring just like the one pictured above and have no doubts or concerns about doing so. Surly rings are good stuff.
    Ed E
    Steel and teeth.
    Reputation: b1umb0y's Avatar
    Feb 2005
    Quote Originally Posted by edemtbs
    Sheared bolts, 4-arm cranks and over-zealous tightening of said bolts are the culprits.
    FWIW...
    I have had this same thing happen twice on 5-arm cranks... and I haven't had any issues with my 4-arm cranks... I guess I learned my lesson.
    One of those failures had the steel chainring go most of the way through my steel chainstay.
    bb
    Apr 2005
    FWIW...
    bb
    Heh-heh, well I better amend my post then. Like you, I have never had issues with my 4-arm cranks...so far. You just made me feel better about my new one again.
    Sorry about your chainstay.
    Ed E
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    I've folded up a couple alu Shiftmano 32t rings, even without breaking a bolt.
    All I can think of, chainline must have been less than perfect to cause it to fail like this?
    I did not contact surly and do not plan to. Moreover, I still think these are our best option out there and I will be getting the replacement soon. I think that chainline was OK.
    Reputation: ionsmuse's Avatar
    Spent all weekend wacking my 32t 104 surly into big pine logs, without a bashring (gonna get me one soon). No worries.
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    So I found a pic of the original poster, Poff, prior to his ring bending exercise...
    Mr. P
    friend of preston
    well now...
    monster quads but no wanger, no thanks
    He who makes a beast of himself, gets rid of the pain of being a man.- Dr. Samuel Johnson
    I dig trails!
    Feb 2005
    Quote Originally Posted by crashomatic
    LOL!
    ....those aren't legs!!!!
    P
    Reputation: dtownmtb's Avatar
    bent surly chainring
    I have bent my Surly 32t chainring - twice. Yeah, it is on a 4 bolt XT crank and I was running a chain guard. The bend was not horrible, but enough to derail the chain. Bent it back both times and went on.
    As thick as that thing is, I was quite surprised to see that happen.
