Steel plus frame that offers dropouts for both 142 and 148mm rear hubs?- Mtbr.com
Results 1 to 5 of 5
    that guy
    My quest: A singlespeed steel frame that can fit both my older 29er wheels (142mm hubs) AND a new set of carbon 27.5+ wheels (148mm hubs).
    Note: My older 29er wheels use Hadley hubs that CANNOT be adapted to 148mm.
    The only frame I've found that has this capability is the Advocate Hayduke. Are there any others that I may be missing?
    Unfortunately, I'm just having a lot of trouble mentally getting past the 7 pound weight of the Hayduke frame... lol
    The Surely Karate Monkey with the Gnot Boost dropouts and handle it.
    that guy
    Quote Originally Posted by jdgang View Post
    Hell yeah! I didn't know about the new Gnot Boost dropouts.
    I'll definitely check it out if/when they manage to release them before March.
    Aug 2010
    I believe the 2017 Nimble 9 is available with both size dropouts. Not specifically a plus frame, but definitely plus friendly.
    that guy
    Quote Originally Posted by racefit View Post
    Do you happen to have a link with info for the 142mm dropouts/adapters on the new N9? My Google-fu is failing -- I can't find anything. Everything I'm seeing is only listing standard 148mm boost.
    Edit: nevermInd, I found their post about it. I love their frames, so this could be a winner; and, it turns out that their gen3 actually is a boost-specific frame. Thanks for the tip!
    Quote Originally Posted by KillingtonVT View Post
    We did a total redesign on the gen 3 dropouts to save weight, unfortunately, the gen 2 dropouts won't fit the new frames.
    We are producing a VERY LIMITED amount of 142x12mm dropouts for the new N9 Boost to help our riders get by until they upgrade to a 148x12mm wheel. Just keep in mind the new frame was designed around Boost with a 52mm chainline, not the 49mm chainline standard that should go with a 142x12mm rear.
  1. Replies: 16
    Last Post: 07-22-2017, 08:10 PM
  2. Replies: 5
    Last Post: 09-03-2016, 02:35 PM
  3. Replies: 6
    Last Post: 10-29-2013, 05:51 PM
  4. Replies: 1
    Last Post: 06-17-2013, 04:24 PM
  5. Replies: 18
    Last Post: 09-13-2011, 12:30 PM
