STEEL chainrings, where??- Mtbr.com
Results 1 to 10 of 10
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    Actually I'm gonna answer that for myself. NOWHERE!
    So basically I'm looking for a 42t in 5bolt 110bcd and a 42t in 4bolt 104bcd. And they have to be thicker than 9-10-11-12 or whatever speeds they are now running. I want the chainring to be perfect thickness for an 8sp chain. Also I'd like some long lasting material. 304/316 and such crap I don't want. Needs to be hardened steel.
    And nowhere can I find this!! I'm starting to get a little pissed off actually.
    Right now I'm running alu rings but I don't think they last very long. I get about 1 year (commuting). My old shimano 9sp steel chainring lasted a lot longer than that. But it had shift ramps. And I'm on a 1x6 (8sp stuff).
    So now I'm considering having a few chainrings made instead. By a machine shop.
    Thinking about using Hardox 500, Hardox 500 - Wear-resistant steel with extra-high toughness - SSAB
    Its about 500 brinell hardness and the yeild strength is around 1400MPa, its at least 3-4 times stronger than the best alu. And probably 100 times longer lasting.
    My plan is to just send a chainring out to the machine shop and say "here copy this in hardox 500", so now I need to know what chainrings are the best ones to copy, Thinking tooth profiles and such. This would be for a 1x6 or so.
    So which ones are good "references" to copy?
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
    Downcountry AF
    Oct 2013
    Surly Stainless Steel Chainring > Components > Drivetrain > Chainrings | Jenson USA
    that will cover your 110bcd ring. it's meant for 7,8,9 spd chains too.
    the 104 42t will be harder to find... if it exists.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: bikeny's Avatar
    If you're on Ebay, try to contact a seller that goes by 713_rogers713. I don't see any of his stuff listed right now, but he has in the past sold custom chainrings made from titanium and quality steel. They're not cheap, but they are worth it. I have a couple of his titanium chainrings and they pretty much last forever. The steel rings should last twice as long!
    Downcountry AF
    Oct 2013
    i found a 104, but it's $194.
    Action Tec Home Page
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    ~ B A D A S S ~
    I just measured my bolt circle on my triple DA cranks and they are 130mm, they looked quite large for 110.
    Regarding actiontec, at 200 a pop I'm quite sure I can have them made out of gold if want to. I'm guessing I will have to pony up a hundred or so a pop if I have them made out of quality steel.
    Downcountry AF
    Oct 2013
    Quote Originally Posted by car bone View Post
    you saw that the Surly ring comes in 130 bcd too right?
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    ~ B A D A S S ~
    Yeah and and I also saw it was made out of 304 stainless, about as strong/long lasting as 6061 al.
    Sep 2015
    better late than never.... some possible alternatives.
    https://www.ravalbike.com/round-chainrings
    Nov 2013
    Quote Originally Posted by bikeny View Post
    I also have one of his ti cogs and it is beautiful and lasts forever. You can also message him via FB. He usually responds within minutes. Search for "Labyrinth Metalworks". He seems to be doing a lot of custom knife work at the moment so I am sure he has a lot of steel sheets laying around
  1. Steel vs. Al Alloy crankset chainrings
    By XCProphet in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2013, 07:47 PM
  2. Shimano steel chainrings
    By noassatall29 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-02-2012, 10:44 AM
  3. Looking for dead steel frames, chainrings, and Cassettes
    By Smoothinto2nd in forum California - Norcal
    Last Post: 03-12-2012, 12:16 PM
  4. Your thoughts Steel vs Aluminum chainrings
    By cbrock450 in forum Singlespeed
    Last Post: 11-10-2011, 09:41 PM
  5. Steel chainrings = more wear on chain?
    By fenrisulfur in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-21-2011, 09:54 PM
