SS setup / gearing / Chain type?- Mtbr.com
Results 1 to 3 of 3
    All Mt, DH
    Reputation: rogue's Avatar
    Hi just been setting up my Chameleon for SS - new to SS (but have several FS...)
    I've set it up with a (not ridden yet) :
    Hone 32 chainring
    16T steel rear cog
    Hope Bulb hub with some spacers etc.
    Chain Shimano CN-7701 9 speed..
    I've been reading some posts on this SS forum... should I ditch the 7701 in favour of a KMC chain (any recommendations?) If I use a KMC is it easy to shorten or lengthen the chain....( I have the Park chain breaker tool.)
    Also I live in Hong Kong and its quite mountainous here, I worry the 32 / 16 combo may be too hard to pedal up.... even though I wont use this bike for any serious climbing...
    Are the Aluminium cogs say 22T up to the task?
    Cheers
    Thanks in advance
    2007 Blur 4x
    2009 Driver 8
    Reputation: philpot's Avatar
    Mate, ride the two to one ratio and see how you feel. You will get stronger after a bit. As for the chain, unless you've got a geared bike you can better use an expensive chain like that on, use it. It ain't gonna break if its new.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    just make sure the cog is not too wide for a 9 speed chain... otherwise as philbot said.. ride a bit and see if the gearing is ok..if not get a couple cogs and start playing with it...
