SS SC Chameleon - Project SS- Mtbr.com
    Hi Everyone,
    For the past month, I've been riding on SS mode on my local trails to 1) see if I like it and 2) try and figure out what gear ratio is best. I'm surpised at how much I'm enjoying it - i'm totally hooked!! So, now I want to drop the $$$ to convert it completly. I'll need a new rear wheel for starters, and new brake levers (I have the LX combo now). In addition, possibly a new bottom braket, but I'll leave that to my LBS.
    So, can you recommend a rear wheel? I'm thinking of the surley 1x1 hub - only because i've seen alot of it (through advertisements and bike catalogs). I have to go custom, because I *have* to have an orange rim for the rear (so it matches my front)... Long story short, I broke to Gary Fisher Paragon frames, and the only thing that held up was the fork and wheels.. both orange!! BTW, I'm 230lbs - not that it really matters, i'll be "giving up" the dish in the rear wheel, so I assume the SS wheel will be much much stronger.
    Thanks everyone!!
    don't give up the rear disc
    check into it. I remember hearing that the new 1x1 hub now has a disc conversion available. If I can find it, I will let you know, but do a search and you should find discussion.
    Quote Originally Posted by nmcculloch
    Oops. Forgot to mention that I have v-brakes now. I'll probably never (only 'cause I never say never) go to disc brakes. Just don't need them in Michigan.
    mm
    ol'guy who says hi &waves
    Reputation: fred-da-trog's Avatar
    Oct 2003
    Surly 1x1
    Picked up a used, home laced wheel with a 1x1 a couple of months ago. It's very convenient and holding up well under my 200# of pounding. Orange is cool. Post pics.
    I may not have the best of everything, but I have the best everything that matters.
  1. Rohloff on a 2003 SC Chameleon
    By Cruzman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2004, 01:41 AM
  2. Norco Sasquatch, SC Chameleon or Banshee Scirocco
    By sbek in forum Bike and Frame discussion
    Last Post: 06-27-2004, 01:05 PM
  3. Santa Cruz Chameleon SS With Rear Disc
    By 2WheelFreak in forum Singlespeed
    Last Post: 05-05-2004, 06:19 AM
  4. Help! Trying to complete my 1st SS project.
    By slow_spoke in forum Singlespeed
    Last Post: 04-27-2004, 07:39 AM
  5. SC Chameleon or Banshee Scirocco
    Last Post: 04-08-2004, 12:04 PM
