ss disc brake ??- Mtbr.com
    ss disc brake ??
    im new to ss world.im thinking of getting an surly 1x1 and build it up with an 80mm
    coil zocci.
    is setting up the rear disc or Vee brakes a hassel since the wheel has to move now for chain tension. or it really no big deal.
    ill be using a 9speed hub with spacers and a bmx cog. what about changing rear gear size
    and may have to change chain length now also.
    thanks
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Not a big deal...
    Quote Originally Posted by bluecruz
    coil zocci.
    thanks
    Disc or V-brakes aren't a big deal. I *think* the 1x1's come with a disc brake adaptor that allows you to move the caliper in to the proper position. V-brakes are not problem, it's simply a matter of adjusting your brake pads.
    Changing gear sizes shouldn't be a problem, so long as you initially adjust your chain length to set in the middle of the horizontal drop outs. This will allow you to change gear sizes without messing with your chain length.
    Perhaps a 1x1 owner can confirm that the disc tabs allow for caliper adjustment.
    Ken
    I am the owl
    Reputation: riderx's Avatar
    Quote Originally Posted by Ken in KC
    Ken
    Confirmed.
    SingleSpeedOutlaw .com
    Riding Bikes and Drinking Beer.
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Quote Originally Posted by riderx
    Confirmed.
    I second that emotion.
  1. AVID mech disc brake question, on a SS....
    By hu-man in forum Singlespeed
    Last Post: 03-07-2004, 10:48 PM
  2. Brake Simplicity For SS ?
    By T 3 in forum Singlespeed
    Last Post: 03-06-2004, 10:57 PM
  3. Avid road disc brake for mtb
    By K2footsrgn in forum Brake Time
    Last Post: 02-17-2004, 01:54 PM
  4. Racer X Disc Brake Mount
    By XC_Miles in forum Titus
    Last Post: 02-02-2004, 10:38 AM
  5. Need disc brake adapter for manitou 74mm to 51mm
    By DIYguy in forum Shocks and Suspension
    Last Post: 01-18-2004, 08:05 PM
