SS Cranksets in 185mm ??- Mtbr.com
Results 1 to 9 of 9
    Looking for a 185 mm cranks for my new singlespeed. The only brands I have found are Zinn and TA Specialties. Are there any other brands that make cranksets longer than 180mm?
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    TA Specialites
    Quote Originally Posted by bone yard
    Just picked up a set as I was in the market for a 185 set. They are super nice looking but I have yet to mount them. The ineterchangeable spider makes them super versatile. I went with the compact double so I could run a bashgaurd or play with the chainline up front. They come with self extracting crankbolts that are a nice touch. The frame I'm using them on is in transit and I'm hoping they'll function as well as they look.
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    Good 'ol Profile racing BMX cranks. Available in 185 & 190.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Zanetti
    Yup. That is what I use (and 182).
    Word is the new Surly cranks will have a 185mm option next year.
    mtbtires.com
    Out spokin'
    Dec 1999
    High Sierra Cycles makes Zinn's cranks. Zinn want $470, HSC charges $350. I just bought a set of HSCs. Tom is a pleasure to work with and the product is quality.
    Zinn
    HSC
    --Sparty
    disciplesofdirt.org
    Thanks for the replys!
    For those who use the profile cranks, do they have a model that fits on square taper BBs, or do you use the profile "splined" bottom bracket as well? (what profile model are you using?)
    Sparty - nice insight on zinn/ high sierra, thanks.
    Dec 1998
    The Profiles are splined only. I use the FSA X-Drive euro BB. Much better than the Profile as it uses an adjustable cup so the bearing spacing can actually be adjusted properly.
    mtbtires.com
    Reputation: MtbFlorida Brian's Avatar
    if you get the profiles beware of the ti version. they are a booger to get on properly
    Dec 1998
    Quote Originally Posted by MtbFlorida Brian
    What ti version? If you mean the ti spindle it is no more difficult to deal with than a steel spindle.
    mtbtires.com
