ss chains- Mtbr.com
Results 1 to 10 of 10
Thread: ss chains
    ss chains
    I'm on my first singlespeed and have never replaced the chain. Looking for a quality ss chain preferably with a quick link. Any suggestions? thanks
    Jimmy for president!
    You don't need a single speed chain. Frequently they are a heavier, and lower quality. A lot of people on here, me included, are running the SRAM PC-58 / PC-870.
    How long is the pc-58 or pc-870 compared to a single speed chain?
    How long? Long enough. Longer than you need it to be.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    And you'll need a chain tool to cut it to the right length, whatever chain you use.
    yeah just was wondering if its too long and i need a tool to cut it down. Thanks.
    local trails rider
    Aug 2005
    Keeping a piece of the extra chain (and a chain tool) with you during rides is not a bad idea, just in case you have some serious chain problem.
    It does happen that a chain fails ... especially at a joint that you just made ...
    I'll also mention, any modern, good quality chain shouldn't be rejoined by simply pushing the pin back in. If you're using a Shimano chain, then you need to use a replacement pin, and most of the other brands use some sort of quick link. Use them, or you'll create a serious weak point in your chain.
    I also carry a couple extra links and a Powerlink in my pack along with the chain tool which is on my multi-tool.
    Ken
    Ken is offline
    Ye Olde Phartt
    Reputation: Ken's Avatar
    Mar 2005
    I'm getting good mileage from the KMC Z610HX DropBuster (3/32"). It has lasted much longer than the Z410s. KMC's come with a quick link.
    Reputation: ernesto_from_Wisconsin's Avatar
    KMC bmx chains
