SS build-up, XT question:- Mtbr.com
    I'm a cutter
    Reputation: redbulltj's Avatar
    I am building up a SS with some extra parts I have, Easton 1s, Reba, Juicy 7s ect..
    I have a XT crank set I want to convert, but with searching I have not found what the chainring measurement is (BCD). I think it's 104. I am leaning toward surly front and rear rings.
    Any quick help out there?
    I have been searching for hours on this site and I have seen many people have done the conversion with this crank-set but noting specific like exact measurements.
    Thanks in advance!!
    1 ☼ ♥
    Reputation: mrkaztro's Avatar
    Nov 2008
    Idea! Here is some help
    Looky Here Take the measurements on your chainring and use the chart.
    If it's a 4 arm, it's 104
    You can also confirm it here:
    http://www.sheldonbrown.com/gloss_bo-z.html
    If it's a much older, square taper XT, it's has 5 arms. That should be 94, but could be 110.
    I'm a cutter
    you guys are good! Thanks....
