SRAM or Shimano BOOST crank recommendations- Mtbr.com
Results 1 to 8 of 8
    Aug 2010
    Switching to a Boost frame and looking for a direct mount so I can run spiderless chainring.
    I've always run X9 and found them simple and easy to use. Not familiar with Shimano cranks.
    Looking for something simple and reliable with good availability of after market chainrings.
    Would also like some clarification on SRAM's new GX and NX and how they compare to X5/X9 etc.
    Downcountry AF
    Oct 2013
    I'd go Raceface Turbine Cinch with boost chainring. what's you budget?
    between Shimano and Sram cranks, I'd go Shimano every time.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Aug 2010
    Doing a quick search and Shimano M-8000 XT keeps coming up. Looks like an integrated spider. Does Shimano offer a spider less option?
    Downcountry AF
    Oct 2013
    Shimano doesn't make a direct mount crank that i'm aware of. that's why i said raceface. They make some nice cranks depending on what you want to spend. also available in 24mm spindle like Shimano or 30mm.
    I have older Turbines on my SS and Aeffect direct mount on my fatbike. i like them both, but if i had carbon crank money, I'd go carbon.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Reputation: OwenM's Avatar
    Oct 2012
    I'd be looking at the Turbine Cinch and SRAM GX1400, too. They're pretty much a tossup. Flip a coin, go on looks or brand preference, etc.
    Turbine Cinch comes with a direct mount chainring, while the SRAM comes with a chainring on a removable spider.
    So, the SRAM is actually a fuzz lighter if you account for saving ~70g of spider, but then you have to buy a direct mount chainring for it. We're talking very small differences in both weight and cost, but in this case, it's actually lighter and as/slightly more expensive intially, instead of heavier and cheaper, as just looking at specs would suggest. The light and inexpensive SRAM Team GXP BB may even things out cost-wise, though, as the RF one doesn't have the best track record(as of a couple years ago, anyway), and may have you wanting to upgrade.
    Whether you consider it a pro or con, the Cinch uses the Shimano ISIS drive crank tool for the threaded ring that holds the chainring in place vs. 3 T25 bolts for the SRAM, which you'll need if you go RF.
    I have the GX1400, but no real preference between the two.
    western NC
    Reputation: HPIguy's Avatar
    Sep 2014
    The Aeffect setup is only 20gr heavier than the Turbine cranks, and $80 cheaper. I'm 210lbs geared up, and have been riding a set (came with the bike) since late January with zero issues.
    Aug 2010
    Is GX = X9? NX = X5?
    Oct 2012
    GX apparently replaces X7/X9, though its components and their construction doesn't quite match up(the 11sp derailleurs have a different design, adding to the confusion), IMO. Then there's X1, which...well, I can't tell the difference just from briefly checking out bikes with both, and am not sure where that's supposed to fall in the lineup. Unless something has changed, though, the GX 1400 and X1 1400 cranks are the same, with matching specs. Ironically, the GX version was $10 more at jensonusa when I googled to double-check before posting this
  1. Compatible chain rings for shimano 2x10 boost crank
    By 156flash in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-27-2016, 09:56 AM
  2. SRAM GXP crank (68/73 threaded), coming from a shimano crank
    By spyghost in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-16-2015, 05:59 PM
  3. Shimano XT crank requires Shimano Chain? SRAM rear compatibility
    By LookerBob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2013, 02:05 PM
  4. Shimano crank with sram components?
    By jcatier314 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-25-2011, 09:09 AM
  5. Shimano XT dyna-sys with sram crank
    By wton5456 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-09-2011, 06:44 PM
