SRAM Powerlink on SS chain...- Mtbr.com
Results 1 to 14 of 14
    Always Learning
    Reputation: BruceBrown's Avatar
    I did search and read a thread back from 2007 where most said they've never had a SRAM Powerlink break on a SS chain.
    After 3 years of using an old chain (no Powerlink) on my SS, I finally broke it this week powering up a hill. I am installing a new Niner rear cog and figured it was time for a new chain rather than repairing the old one. I've got a new SRAM chain in the parts bin, so figured I would use it.
    Am I good to go with trying the Powerlink on my SS?
    TIA
    Reputation: Some1callthekomsquad's Avatar
    Aug 2015
    Good job!
    Quote Originally Posted by BruceBrown View Post
    TIA
    Yes
    May 2005
    Yes, no problems here too
    Reputation: azjonboy's Avatar
    Yes. Been using them for 10 years on my SS.
    If you're lucky enough to be in the mountains,
    you're lucky enough.
    Always Learning
    Thanks all! New chain with Powerlink is now installed with my new Niner 17T cog. It was a nice little New Year's Day project for my Karate Monkey.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    I have broken several 9 spd Power links on the SS over the years....it happens.
    Bicycles donít have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
    Aug 2013
    I have had no problems for 3 years on 8 speed powerlinks
    Sent from my VS986 using Tapatalk
    Reputation: bit_lizard's Avatar
    Aug 2005
    We the people ...
    Quote Originally Posted by mtnbikej View Post
    Says the guy that also broke 3 frames
    I should be out riding
    Reputation: ACree's Avatar
    Sep 2004
    TIA
    As a Clydesdale on SS, I put some stress on drive trains.. No problem with the power link as originally installed.
    Only got about an hour of use when I tried to reuse one however. I won't try that again.
    If it's not powered solely by you, it's motorized.
    Worshiping at the Church of Singletrack since 1993.
    May 2014
    Yes running 2 on one of my chains. No troubles
    Reputation: KevinGT's Avatar
    Dec 2012
    I ride with a group of about 12 other SS'ers and the majority of them are on SRAM 8 and 9 speed chains with Powerlinks and have had no issues. Most of them are re-using them as well. One guy removes his chain every few rides and uses the same powerlink with no issues.
    I just switched from a SRAM P7x chain to a 971 with a powerlink and have had no issues.
    SS Pusher Man
    Sep 2001
    Quote Originally Posted by bit_lizard View Post
    .....it happens.
    Jan 2016
    Depending on gearing I run 2 with no issues.
    Reputation: Andy R's Avatar
    Nov 2008
    I've used Powerlinks and not had any problems with them but I much prefer the traditional joining link on a singlespeed. Far easier to remove and refit, in my opinion.
    I'm disappointed to see that KMC have given up supplying one with the Z-610 HX chain, instead using the Powerlink type. Who needs that on a singlespeed?
  1. SRAM Powerlink with Shimano 10 spd Chain
    By Straz85 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-04-2012, 06:51 PM
  2. SRAM powerlink
    By captnpenguin in forum Singlespeed
    Last Post: 08-09-2012, 06:39 AM
  3. 9-Speed SRAM PowerLink on 10-Speed SRAM Chain?
    By mawiv in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2012, 05:59 PM
  4. SRAM 10-spd Powerlink on a KMC chain?
    By TiGeo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-16-2012, 02:18 PM
  5. sram powerlink
    By Eric Z in forum Beginner's Corner
    Last Post: 07-15-2011, 07:29 PM
