SRAM PC-1 Nickel Singlespeed Chain- Mtbr.com
Results 1 to 12 of 12
    Any opinions on this "singlespeed specific" chain from SRAM? It's only $10 at Performance: http://www.performancebike.com/shop/...estore_ID=431#
    Wondering if this will offer equivalent performance as an 8-spd SRAM chain.
    Thanks.
    Reputation: scanjok's Avatar
    Quote Originally Posted by tingj
    Thanks.
    I used it a bunch cuz they were cheap but had them pop off a few times, I think cuz it is wider than most chains. I now use the the PC58 had no problems, I have not tried the more expensive chains and I usually buy a few of the PC58's when they are on sale.
    My bad. I should have searched the forum before I posted. Anyways, it seems the consensus is that the PC-1 is a cheap, heavy chain that doesn't work as well as the PC-58. Based on what I just read, I am going to pass on the PC-1 and fork out the extra $ for an 8-spd chain.
    Thanks.
    Reputation: noslogan's Avatar
    I like the chain
    Five 24 hr races, 30 laps? and Sat. and Sun. rides and only ONE chain pop. 1500+ miles.
    I like the chain.
    Reputation: pacman's Avatar
    See Nashbar
    Thanks.
    The PC-1 is a dog, but the PC-7X (discontinued ) was great - never broke.
    You don't need to fork out extra money for $6.95 you get a KMC Z510 at Nashbar.
    cut like the fog.
    Reputation: bones's Avatar
    it's a POS
    Thanks.
    I had terrible chain drop with it, and yes my chainline was perfect. I switched to a PC-68 and haven't had a breakage or problem since. The price doesn't make the PC-1 worth the hassel.
    b.
    Cubicle Fugitive
    Reputation: czardonic's Avatar
    No problems here. I've never had one break, nor any issues with chain drop and I rarely do more than eyeball my chainline. Currently running two on 3/32" cogs and chainwheels.
    I guess I better knock on wood, as it seems this chain has earned a lot of enemies. I'm not sure I understand what the exact issues are though. . .
    Not because I'm fast.....
    Reputation: 2farfwd's Avatar
    [QUOTE=pacman]The PC-1 is a dog, but the PC-7X (discontinued ) was great - never broke.QUOTE]
    Do a search on Ebay...I have a new PC-7X I just put up on auction. Sorry for the spam.
    Reputation: PinsNeedles's Avatar
    I'm another one
    that has had problems with chain drop and stretching with a PC-1, I would try the PC-58 as per my team mechanic.
    I just bought a gold KMC to try today for 10 bux...I like gold.
    ' Bend's dirtiest Acupuncturist '
    bendoregonsinglespeeders
    teamwebcyclery
    industry employee
    Reputation: mtbzone's Avatar
    Jun 2005
    The PC-1 is a 1/8" chain, not 3/32"
    The Sram PC-1 chain has 1/2" x 1/8" links...it's made for single speed BMX bikes with 1/8" chainwheel/freewheel. If your running a 3/32" drivetrain then you'd be better off to use a 3/32" chain.
    mike
    Thanks for the input. I am going with a 8-spd chain.
    Anybody know the differences between the PC-58 and PC-68? They are both on sale right now and I am going to pickup a half a dozen. Just wondering if there was a compelling reason the spend the extra $$ for th PC-68. Right now the price difference is not that much.
    Regards,
    Jess
    industry employee
    Jun 2005
    here's some info...
    The PC-58 is a double peened (the way they press the pin to make the plate stay on) and the PC-68 (used to be the PC-61) is quad-peened which gives the PC-68 better side load stength. Be aware that with the PC-68 you will need to carry a 8sp Sram Powerlink connector with you because you cannot press the quad-peened pin back in with a chain tool.
    mike
  1. Homer Jersey - UPDATE (Design, Sizing & Ordering)
    By CrashTheDOG in forum Turner
    Last Post: 08-10-2006, 02:00 AM
  2. Mountain Bike Gear Ratio Calculator V4.0
    By FireDog46 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-29-2004, 11:57 AM
