Sram 11 speed to singlespeed- Mtbr.com
Results 1 to 7 of 7
    Reputation: loOse1's Avatar
    Hi all,
    I want to convert my Borealis Echo to single speed- my plan is to use a Singleator for chain tension (unless some one has a better suggestion?)
    I'm having trouble finding a spacer kit for the freehub though- it seems like there are plenty of options for 8 and 9 speed freehubs but not for 11?
    Do I need to replace the free hub or is there a product out there that will work with a Sram 11 speed?
    Google and search here has not produced the answers I seek...
    Thanks in advance for any insights, this forum is an awesome source of info.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    If you have a SRAM 11 spd cassette with an XD Driver on the hub, you will need to swap the driver over to a normal Shimano freehub. At that point it is just spacers and a cog.
    Bicycles donít have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
    Reputation: Andy R's Avatar
    Nov 2008
    If you have ISCG mountings then I'd use a Blackspire Stinger as a chain tensioner, rather than a spring loaded type. That way you'll completely remove any chain slap issues.
    Mar 2015
    Singleator is gross. If you have to buy one get the spring that pushes up. This Melvin Chain Tensioner ? Paul Component Engineering looks like it might work.
    Still having trouble figuring out the freehub situation- sure would be nice if there were a spacer kit for the sram freehub...
    I'm pretty sure the singleator can be mounted under the chain? Sure look like the melvin does not? No ISCG mounting so I think I'm stuck with a hanger mount tensioner?
    Thanks for the replies everyone
    Jan 2009
    What specific hub do you have? Find the Shimano-type freehub for it and you're set.
    Quote Originally Posted by mack_turtle View Post
    Actually need 2-
    Fat wheelset is a borealis hub on 100mm Nexties
    29+ is turnagain hub and velocity duallys
  1. SRAM X9 10 Speed Derailleur and SRAM 11 Speed Shifter
    By Crooked Cop in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-14-2015, 05:13 AM
  2. SRAM X01 11-Speed X-HORIZONô Rear Derailleur compatible with sram 10 speed ?
    By cxboy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2015, 08:38 PM
  3. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 09:43 AM
  4. 9-Speed SRAM PowerLink on 10-Speed SRAM Chain?
    By mawiv in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2012, 05:59 PM
  5. SRAM Crank X7 GXP 3.3 - Triple 10-Speed with 9 Speed SRAM cassette
    By kragu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2011, 08:42 PM
