Special ENO crank chain...wheel (?) tool question- Mtbr.com
Results 1 to 9 of 9
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    First of all, is it still a "chainring" if it's not really a ring but rather a disc, plate, or wheel? Chaindisc? Chainplate? Chainwheel? Sprocket?
    Okay, to the real question: what tool (or method) are you all using to remove the lockring when it's time to change chainrings? The diameter is too small for my "normal" spanner, and I'm told that White Industries isn't selling their dedicated tool.
    34N 118W
    Reputation: Hollywood's Avatar
    'nother thread
    there was a fairly recent thread discussing this same topic - maybe search or scroll down a bit. Bottom line was a spanner does the trick. White Ind. directly recommended the "hook" end of a BB tool but that didn't cut it at the shop. The cranks in a vice and a spanner in 2 of the 3 notches was the tikit.
    Quote Originally Posted by Nat
    Nat
    Nat is online now
    Thanks.
    Reputation: Ilegal, Y Que?'s Avatar
    Apr 2005
    Nat,
    That was a thread started by me. IMHO, I think it's crazy to not produce a tool for the lockring on the chainring. It would be on par if WI produced the ENO freewheel and didn't produce a tool to remove it other then saying-use this tool from Park Tools, it doesn't really fit, but with bound determination, you will get the freewheel off.
    I had no luck using the spanner. I use the SPA-4. Doesn't really fit, but it will work.
    email WI and tell them about it. With enough emails, they will produce a tool for it.
    good luck.
    King Pin
    Reputation: xrmattaz's Avatar
    Good job! Hozan
    The double-ended locking ring/BB tool from Hozan works wonderfully!
    Nat
    Nat is online now
    Quote Originally Posted by xrmattaz
    It fits snugly without play?
    Nat
    Nat is online now
    Quote Originally Posted by Ilegal, Y Que?
    Nat,
    good luck.
    Yes, I agree they should make a tool if no one else (i.e., Park Tool) makes one. I took your suggestion and emailed WI about it.
    King Pin
    Smile
    The larger end fits the lockring nicely. It's not a "custom" fit, but no chances of slipping and/or damaging anything! I also put the crank arm in a padded vice. I've been using the same wrench for several years and now three sets of ENO cranks.
    Nat
    Nat is online now
    Excellent, I'll find one of those tools. Thanks!
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. Greasing bottom bracket spindle?
    By Belfrey in forum Tooltime
    Last Post: 07-24-2005, 11:09 PM
  3. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  4. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  5. What's the white goop on my bb spindle?
    By Spoiler in forum General Discussion
    Last Post: 02-19-2004, 11:16 AM
