smallest safe cog- Mtbr.com
Results 1 to 9 of 9
    smallest safe cog
    subject says it all really, 16t seems as low as people go
    i understand the reasons against it but is anyone here using a really small cog?
    any catastophic parts failures you would liek to mention?
    Reputation: PeanutButterBreath's Avatar
    Check the Urban/DJ/Park board. Some of those riders use really small chainring/cog combos for better clearance.
    Looking to Start Racing
    Reputation: TREK 4 Life's Avatar
    Feb 2006
    I'm in the middle of a conversion right now. And I'm getting a 16t with the kit. But thats just to "easy", so I will be going with a 14t. I'm gunna use a Rennon in push up mode, so I will have more chain wrap.
    Evolve or Die
    ok currently i run 42:18 on my commuter which is a 2.33 ratio
    i have just parted ways with this bike and i am picking up a new one which is currently 32:18 -trying to work out the easiest way to change gearing from 'commute' to 'dirt' without having to break the chain every saturday morning
    i want to see what people think about 32:14 gearing which is a 2.28 ratio
    also thinking of a 32:13 combo so it is a bit faster on the road, will this be a chain destroyer?
    I doubt you can go from 18 to 13 in the back with the same length chain anyway, unless you are using a derailleur or Melvin as a tensioner.
    not even by playing with where the wheel sits in the dropout?
    dirty hippy mountainbiker
    Reputation: wolfy's Avatar
    Dec 2004
    Probably not, but you could use an extra few links of chain and another quick link to easily lengthen/shorten the chain. Or run double double.
    -M
    Mike Henderson, Dirty Hippy Mountain Biker and part owner of Jet Lites.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by alexb618
    ... -trying to work out the easiest way to change gearing from 'commute' to 'dirt' without having to break the chain every saturday morning...
    Use two chains, one for each gear combo, with masterlinks or SRAM PowerLinks. Quick and easy swap.
    mtbtires.com
    Quote Originally Posted by shiggy
    i thought it would come to this. i guess i will have to outlay some cash on another chain, was hoping to be able to change things with what is already on the bike
    ah well!
