Smallest freewheel for Phil Wood rear hub- Mtbr.com
Results 1 to 6 of 6
    I've Googled this but little clarity. For whatever reason the PW site apps won't open for me to view the content.
    I have a PW threaded MTB rear hub (New) and want to put a 15t freewheel on it. Do I have other options lower than 16t. Googling has lead me to think they don't get smaller and still match threads.
    Any help is appreciated.
    Cheers.
    Jan 2009
    I think someone made a 15t freewheel to fit standard hubs at one time, but I don't see it anywhere now. typically 16t is the smallest unless you use a bmx flip-flop hub with metric threads on one side, in which case you can do down to 13t.
    Positively negative
    AC Racing 888. I had one in my parts bin for roughly a decade before I gave it to away, or lost it, or something. Good luck.
    Scratch that, I do still have an 888. It was in my swap meet box, but it's a 14t.
    Quote Originally Posted by big_papa_nuts View Post
    Also had and maybe still have an AC racing freewheel. It was not the greatest, got pretty crunchy and skipped often. Was the 15t model I believe.
    Note: I think that combination of Phil hub and AC 888 freewheel required a spacer to work. I remember the freewheel body being so low profile the outer rotating part touched the hub body just enough that it wouldn't function.
    Ok. I trust that my searching and your answers tell me that it's not likely a dependable 15t is out there. My next step is to experiment with the front sprocket and R-Chainstay clearance. I've heard of guys going up to 33 on my particular frame but chainline is suspect.
    Huge thanks to all.
    Jan 2009
    If you want a reliable freewheel, stick with 16t and adjust your chainring size accordingly.
  1. Is Phil Wood the only 100 mm S/T BB?
    By deuxdiesel in forum Fat bikes
    Last Post: 09-09-2014, 12:56 AM
  2. Q: Pugsley and Phil Wood BB
    By mesier in forum Fat bikes
    Last Post: 12-26-2013, 05:53 PM
  3. Paid spam: Phil Wood KISS Off Rear Hub
    By cornice6 in forum Singlespeed
    Last Post: 02-08-2011, 05:32 PM
  4. New (to me) Phil Wood SS
    By jboyd122 in forum Singlespeed
    Last Post: 01-31-2011, 10:35 PM
  5. New (to me) Phil Wood (Sycip)
    By jboyd122 in forum Custom Builders & Other Manufacturers
    Last Post: 01-30-2011, 12:25 PM
