Smaller chainring, larger rear cog.Gear Ratio Help...- Mtbr.com
Results 1 to 16 of 16
    Dec 2008
    So as a general most single speeds are 32 chainring and 17,18,19,20 rear cog..... but I've seen a few here lately that are running much smaller chainrings and larger cog..... what is the reason!!!!!!! is it better and why....
    Reputation: Andy R's Avatar
    Nov 2008
    Reducing the size of the chainring and/or increasing the size of the rear sprocket = lower overall gearing, obviously.
    And it is a sprocket (designed to mesh with a chain) not a cog (which is designed to mesh with another similar cog, like in a gearbox).
    Another word that gets mis-used now though, like "shock" instead of suspension forks.....
    Out spokin'
    Dec 1999
    Quote Originally Posted by Andy R
    Huh. Never knew this... about the word cog. Oil well, I'm gonna continue to misuse it... but at least I'll know I'm doing so.
    --sParty
    disciplesofdirt.org
    Mtbr Forum Sponsor - Homebrewed Components
    people are getting weaker?
    Out spokin'
    Dec 1999
    Quote Originally Posted by ISuckAtRiding
    Won't speak for everybody, but I most certainly am.
    --sParty
    disciplesofdirt.org
    Quote Originally Posted by hdkiwi
    I have a 28/19 setup (1.47 ratio). Why so light you ask? I live in an area where there are lots of steep climbs and technical areas. Anything higher and I burn out instantly on the climb or have to get off for all of them.
    I don't mind spinning out on the flats because there aren't any.
    When it comes to down, there isn't pedaling anyway because we can pick up so much speed or we are on the brakes for the tech-bits.
    For me it's all about making the climbs.
    this space left intentionally blank
    i wonder if he means smaller in the front and smaller in the rear? Like a microdrive setup?
    If so, it gives you a little more ground clearance, and it's lighter. However, it wears everything out faster.
    Low Rep Count
    Reputation: 1SPD's Avatar
    But can you really call a Lefty a Suspension "FORK"?
    Seriously, I know some guys have dropped down to a 24t front w/ a 12t rear. (Micro drive) The ratio is still pretty much the same but they shaved weight by running this set up due to the parts being smaller.
    Nov 2008
    Pretty much the same here, but 32:20 on a 26" wheel (41.6").
    All up or down and mostly pretty technical - it's all about making the climbs for me, too.
    Ride, Sleep, Work
    Reputation: MichaelW's Avatar
    I run a 32/15 to race on and a 32/17 when I go to the mtns. I feel that I am getting stronger. Easier gears are just not fun. It is ALL about speed!
    Click to save 15% off your 1st Hammer nutrition order
    http://www.hammernutrition.com/affiliates/50110
    Linoleum Knife
    Reputation: forkboy's Avatar
    nm
    Quote Originally Posted by forkboy
    nm
    you edited your post, but i read it before you did, and you said "dampener". You mean like a squirt bottle?
    Or did you mean damper, like a rebount/compression damper?
    Linoleum Knife
    Exactly! I had a couple other errors in there that I was going to get called on...
    But according to dictionary.com, the alternate meaning of Dampen is to dull or deaden; depress, so a dampener could be either a deadener or a moistener.
    Just depends which version of English you are using.
    Out spokin'
    Dec 1999
    Heh heh... you said rebount.
    --sParty
    P.S. Sorry to be posting so many lame replies last couple of days but I'm at home... sick... can't ride... bored to tears... anyway you guys are my victims.
    disciplesofdirt.org
    Reputation: rob_co2's Avatar
    Quote Originally Posted by MichaelW
    Agreed. I guess I'm just used to mashing, but I tried a 32x18 last weekend (change from usual 32x16) on a course with some lite climbing and hated it. Spinning fast up the hill feels like riding a geared bike.
    --sParty
    you know they stopped using Codine for coughs and colds years ago, right?
