Small singlespeed crank- Mtbr.com
Results 1 to 6 of 6
    Does anybody make a single 24-tooth (or 22) chainring crank? I realize I can simply use a triple mtb crank and take off the outer two chainrings, but I don't really want to do that. Thanks for any suggestions.
    Bikes not Bombs.....
    Reputation: SS Jerry's Avatar
    White industries Eno goes down to 32T
    Quote Originally Posted by Buonarroti
    You might be able to get a spider for straight pipe cranks like profiles or cook brothers and install a 24T or 22T. Not sure if anybody make a single ring for XTR's that small?
    All the others I have seen are BMX related and usually have 122mm and wider Q factors for the BB.
    This may not help with your chainline unless you plan on placing the cog right next to the lockring. This may present a problem with the cog hitting chain stay.
    Avid made a chain ring adapter many years ago to allow a super low ring in the front, but most compact drive systems can now utlize a 20T.
    JS
    Thanks to all of you for your friendships on this board..... -
    After doing several bike tours, I realized that I can get away with using just a single 22 or 24 teeth crank up front and a 11x32 cassette in the back. The highest gear would be about 50 inches, which is way plenty for me since I tour at a slow pace with panniers. Thus, I can get rid of the front shifter, cable, front derailleur, and just have a simple one chainring crank - sort of like what single-speeders use, but with a much smaller ring. I'm thinking I could set the chainline right in the middle of the rear cog and not have too much crossover. You think that's a good idea? I'd be willing to even go with a child's crank or BMX, provided it's Shimano-level quality.
    all hail der Fuhrer Bush
    options
    that small a chainring will take a toll on the chain and the little chainring. you'll also have a little more friction compared to using a larger ring.
    a 28t steel granny ring on a standard bcd crank would make more sense; with a 34t large cog in back you'd have a decent climbing gear, my double crank setup uses a 29/34t low and I get up stuff just fine.
    that said. I've made what you seek from a 58/94mm compact triple by just hacksawing off the middle/big spider arms and then filing until it looks purty. easily done.
    I have a trials crank with just a 58mm bolt circle here, but it's got 170mm arms, probably too short for your use, that I could be persuaded to part with.
    Candlestick Maker
    Reputation: baker's Avatar
    A Trials crankset would be one option...
    http://webcyclery.com/.docs/product_...t_details.html
    Thanks for all the suggestions so far. In addition to the Truvativ cranks, here's another one I've seen, although it only comes in a 32 tooth:
    http://www.chainreactioncycles.com/k...s&ModelID=3348
    This sort of crank is exactly what I'm looking for: clean look, one-piece, and no excess machining. Too bad it only comes in 32 teeth. BTW, can "trial cranks" handle daily use?
  1. Greasing bottom bracket spindle?
    By Belfrey in forum Tooltime
    Last Post: 07-24-2005, 11:09 PM
  2. What's the white goop on my bb spindle?
    By Spoiler in forum General Discussion
    Last Post: 02-19-2004, 11:16 AM
  3. Is Turner's small small enough?
    By CrashTheDOG in forum Turner
    Last Post: 02-01-2004, 05:16 PM
  4. chainring sizes for 110bcd - crank trade?
    By qtip in forum Singlespeed
    Last Post: 01-28-2004, 11:20 AM
  5. stripped crank arm removal
    Last Post: 01-26-2004, 02:15 PM
