Sliding drop-outs?- Mtbr.com
Results 1 to 14 of 14
    I fix choppers
    Reputation: HELLBELLY's Avatar
    New question here. Sliding drop-outs?
    I have a couple of questions regarding sliding dropouts like the ones found on this Kona.
    Does anyone have any experience with these good or bad? I want to have disc mounts put on my Spot and this seems like a more simple and elegant solution than going with an EBB. Does anyone know of any builders that will do this?
    semi-evolved simian
    Reputation: Mine'sAPint's Avatar
    Quote Originally Posted by HELLBELLY
    FONT=Trebuchet MS]I have a couple of questions regarding sliding dropouts like the ones found on this Kona.[/FONT]
    They work great on my Explosif, just good experiences so far I don't know about custom builders that do them, but I think they're normally referred to as Rohloff dropouts (to be used with the Rohloff Speedhub).
    Cracker-magnon
    Reputation: gpsser's Avatar
    Poke around Rohloff's website. I found some specs there once for builders in pdf format. It was rather burried there and I am not sure where it was. You may be able to contact them and see if they sell the dropouts to builders
    "Life is a [email protected]#^ing story problem, get used to it - my son.
    Ground Up
    Eric from Ground Up Designs in Colorado Springs has a similar design to the Kona's. I have one of the first three bikes with them. The drop outs are simple, easy to set up, and significantly lighter than the EBB. Eric is wonderful person to work with too.
    http://www.groundupdesigns.com/
    Zippy, the wonder bike
    Go to www.brodiebikes.com and check out their 1Ball, very similar to the Kona Unit.
    paintbucket
    Reputation: wooglin's Avatar
    Voodoo is also using sliding dropouts, slightly different from the Kona's. Don't know where they're coming from though.
    <img src ="https://www.bti-usa.com/pictures/VD/VD1615.JPG">
    When the going gets weird its bedtime.
    theHeadlessThompsonGunner
    Reputation: SDizzle's Avatar
    I think we've met, right across from Greenbriar about two months ago... I have a baby-blue SC Chameleon/Red Z1 - your bikes (+ wife's) were just stolen. Right? Anywhoo, if I'm correct, how's the new ride(s) working out? I'd be interested to see them sometime, and to ride with you! Adios - Stefan
    "I've courted brain damage like some courtesan of darkness."
    -The Good Doctor
    Brakes?
    Reputation: pimp-daddy's Avatar
    Good job! Sliding Drop-outs...? Van Dessel!
    YO!
    My new Van Dessel Buzz Bomb (Thanks to Applesseed), is "da-bomb".
    The sliding dropouts have been fine so far. No problems. I've got a torque wrench and make sure I torque to bolts properly to ensure that I don't over tighten.
    DO IT!!
    JohnnyD
    Trail Pimp Numero-Uno
    MO-IMBA Rep
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    unauthorized photo
    we see a lot of pretty cool bikes and or people in Fruita.
    I've been inside too long.
    Out spokin'
    Dec 1999
    That is the Voodoo
    Quote Originally Posted by KgB
    I like the fwd-facing set screw on Voodoo's sliding dropout.
    --Sparty
    disciplesofdirt.org
    voodoo is using?
    dont you mean voodoo was using those dropouts? Didnt they go under, or are they back?
    Reputation: the Inbred's Avatar
    they're back
    On MTBR hiatus :(
    Quote Originally Posted by pimp-daddy
    Where'd you get the torque specs from? Neither Edwin @ VD nor Thomas @ Rohloff could give me torques. I figured on about 18 ft-lbs for the Buzz Bomb. What have you got?
    Hellboy, it's a good system but like EBBs they're not designed to be adjusted on a regular basis. I've had to lightly file risers off mine because tightening them down slightly deformed the "channels" that that slide around the bolts, making it difficult to adjust. But they're sturdy and stand up to a bunch of banging around.
    Reputation: nightfire's Avatar
    The new Tinbred has them on. Nice. The steel one will soon follow.
    Ferrous will also be using them on new bikes if specified and I am concidering a retrofit.
    Rolloff ones have an elongated slot on the non-driveside to facilitate the key that prevents the key turning.
    P::..
  1. Replies: 7
    Last Post: 04-28-2004, 10:01 AM
  2. important: drop crown owners (any models on any frames)
    By oli_f in forum Downhill - Freeride
    Last Post: 04-19-2004, 09:33 AM
  3. Some better Pictures of our new drop and some jumpin
    By ThoughtfulPirate in forum Downhill - Freeride
    Last Post: 04-05-2004, 01:19 PM
  4. Pictures: sunset jumping, berms, super ghetto drop
    Last Post: 04-04-2004, 03:37 PM
  5. Replies: 15
    Last Post: 03-20-2004, 03:39 PM
