singlespeeding on the road.....- Mtbr.com
Results 1 to 25 of 25
    Reputation: AkDave's Avatar
    New question here. singlespeeding on the road.....
    I want to give ss a try on the road. I have HT which is disc specific so I have a 700 wheelset for it also. I'm wondering if I need a diff rear cog for each set up? I will run a 32t up front so what rear would you guys suggest starting with?
    Thanks,
    Dave
    Idaho Transplant (closet roadie)
    bike geek
    Reputation: tamjam's Avatar
    Quote Originally Posted by AkDave
    Thanks,
    Dave
    My road SS commuter is set up 40:17, which is a pretty easy gear, but it's what I had lying around. My commute is mostly flat, save for 2 short uphills, generally with a strong headwind, so the gear works out ok most days. To get the same gear w/a 32t ring, you'd have to size down your rear cog to a 13 or 14. If you have a larger spare front ring, and aren't using compact cranks, you might be better off changing that instead of your rear cog.
    Thanks,
    Dave
    go bigger up front for road and consider that 700c will change your expected gear inches/gain ratio/etc; perhaps a 38 or 40t front (should clear stays on middle ring position)and 14-16t or 16-18t, respectively, in back. riding w/freewheel on the road gets pretty boring after you get used to your gear; i might consider fixed as it keeps you engaged the entire ride.
    .02, marc
    Let me ask my wife
    Reputation: HoSS's Avatar
    I run 44/16, 72 gear inch, which is perfect for my hilly commute. The hills around here are mostly short and steep with a few longer climbs.
    You may want to consider fixed also. I found with a SS I did a lot of coasting. Didn't like that at all. Good luck and enjoy.
    “Nothing compares to the simple pleasure of riding a bike.” John F. Kennedy
    I'm sticky
    I'd ditch the 32T chainring - get something bigger.
    For 700c wheels (depending on your tire size) you'd probably want to run 32:12 or 32:13.
    Those are some pretty small cogs. Surly makes a 13T... not sure if anyone makes a 12.
    Shoot for about 70 gear inches.
    This may be helpful:
    http://sheldonbrown.com/gears/index.html
    Thanks for the info.......
    Quote Originally Posted by pcrap
    I appreciate everyones imput. I will check out Sheldons info and go from there.
    Dave
    Bigger than Big
    Reputation: Schecky's Avatar
    Here's my roadie:
    Gitane Tour de France
    I went 42 x 16 for my almost flat area.
    "Get back to the hills, get back to baby where you belong." - P. Westerberg
    Reputation: Cygnus's Avatar
    watch the chainstay with big chainrings...
    I went that route, first with a 44 tooth chainring. only 1mm of clearance on the chainstay. too close for comfort, especially with a bit of frame flex. this is with chainring mounted inboard for chainline with an SS freewheel. now ride a 42x16 on the road. flattish, with some hills and wind. nice all around cruising gear.
    I'll be running a cass wheel w/spacers
    Quote Originally Posted by Cygnus
    I will be using my current rear wheels which are cass hubs so maybe I will have more room to adj chainline than you. My HCR's drive side chainstay is shaped differently and does provide extra room to keep from having chain/frame contact. Maybe it will work. I will just have to exp.
    Dave
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    one day i hope to have a dedicated ss road bike. until then i run a 2:1 mountain bike on the road...if i am spinning too much i simply deflate the tyres or add a loaded back pack...sure 20kmp is slow but i am still hurting when i get home.
    the low km training programme is great for sand-bagging, well once i start beating people that's what they'll call it.
    Expert of the Internet.
    BECAUSE I SAID SO
    Reputation: Aldone's Avatar
    Dec 2005
    I use 53-18 on this:
    It's quite hard but it's very fast on flat land
    my blog: BICIFISSA
    Reputation: Go Kart Motzart's Avatar
    I just put together my first fixie and have enjoyed it (two whole rides). I run a 46/18, but wouldn't mind going a bit larger.
    I'm sticky
    Go Kart Mozart -
    She's a BEAUTY!!!
    The essence of simplicity.
    Reputation: mainlyfats's Avatar
    Singlespeed MTB on the road
    I've got a 34/19 26 inch wheel, 34/12 700c set-up as of tonight. It should work with my eccentric BB, but I'll post an update.
    Just Give'r!
    Reputation: cmatcan's Avatar
    go kart-
    sick bike man, simplistic and STELLAR. but comin from a roadie....lose the poggio or w/e saddle that is and hook it up with a nice slick-lookin road saddle. (did somebody just say SLR???) or at LEAST a flite.
    Quote Originally Posted by cmatcan
    go kart-
    Thanks for the comments guys.
    Your reading my mind on the saddle. It's quite horrible to sit on and look at. Most of my bikes have Flites and I'll stick one on this soon.
    Also, the seatpost needs to go. I like Thompson stuff, but a Nitto (or similar) would be more fitting on this bike.
    French for "Suck"
    Reputation: Aeroplane's Avatar
    Quote Originally Posted by Go Kart Motzart
    If you can find one, the miche supertype seatposts are gorgeous...
    May 2005
    45x16...what a terrible pic
    Just Give'r!
    Vegas, that trek is SWEET!!! my favorite SS ive seen in a while. verry cool.
    j77
    j77 is offline
    Reputation: j77's Avatar
    46:16 SS/fixed flip-flop rear
    My ex-MTB turned commuter / bar hopper fun machine.
    May 2005
    Thanks. It's what trackies do when there is no track
    Reputation: sylvain's Avatar
    54 * 17 with 26" wheels and 1" slicks here (yes there is a tire on that Crossmax rim), works great for my fast flat-ish commute (but I've been up some decently steep hills too, albeit very slowly).
    In this size ring and King Kog should last forever
    Road set up
    Quote Originally Posted by mainlyfats
    Here it is. Chris King hubs with a 12 tooth cog, on Open Pros with Conti 3000 700x23 tires. The chainring is 34.
    I ride this
    on the road, running 50;17, pretty much all year round, she cruises about 18/20mph.
    used to be uno-speedo....
    Reputation: dirtdrop's Avatar
    42x16 and love'in it.
