Singleator tech question...- Mtbr.com
    Apr 2005
    I recently purchased a singleator and installed it on my old Fila Taos MTB, in the process of the install, the O-Ring around the mounting bolt came out, i dissasembled it and reinstalled the o-ring, but it fell out again the next time i mounted it
    how critical is the o-ring, i don't ride the Fila off road that much, and never in wet conditions, so mud won't be an issue, but i can't get the sodding o-ring to stay in place
    which would be the preferred course of action here...
    1; disassemble the singulator *again* (sigh...) and reinstall it, hoping that 3rd time's a charm
    2; get some automotive silicone adhesive and put a thin bead in the gap where the o-ring goes
    3; forget about the o-ring and don't worry
    Brian, there's a message in my Alpha-Bits, it says "OOOOOOOO"
    Peter, those are Cheerios
    Gears, we don't need no steenking gears!
    Reputation: ssbn742's Avatar
    Feb 2005
    I had the same problem with my Singleator oring. I really don't think it will be a problem if you keep it clean.
    "The stupid shall be punished."
    Quote Originally Posted by MacTech
    How did it just fall out?
    Must have been in contact with some other form of cleaning agent or fuel to make the o ring lose its shape.
    I have had my singulator apart a few times and the o ring has always stayed in place.
    I think the o ring is there to prevent water ingress,if you run in mainly dry conditions (Lucky B*****d) then you could probably get away with coating it with grease to seal it that way.
    Apr 2005
    the process of tightening the mounting bolt pushes the o-ring out, had it apart 3X, happened every time
    maybe the headseat/bracket grease would work to keep it clean inside
    i've got an e-mail into Surly anyway
  1. Replies: 154
    Last Post: 03-10-2005, 07:49 PM
  2. Replies: 4
    Last Post: 03-07-2005, 09:09 AM
  3. Replies: 0
    Last Post: 01-06-2005, 01:17 PM
  4. Replies: 0
    Last Post: 01-06-2005, 08:44 AM
