Single Speed on a DH Rig??- Mtbr.com
Results 1 to 7 of 7
    dh mike
    Sep 2004
    I have had terrible luck with derailleurs and derailleur havgers on my dh rig
    went tthrough 5 hangers and 3 derailleurs
    they just cant take the punishment
    i was thinking about getting a road derailleur to thake up some of the chain slack but
    i think eliminating the derailleur the hangar and some excess chain will solve my problem for sure
    so has anyone tried it before
    thats a good ratio to use
    i was thinking 42 front witha either a 16 or 18 tooth out back
    Reputation: shiggy's Avatar
    Dec 1998
    What about the suspension? It does have rear suspension I am guessing.
    Unless the swingarm pivots around the BB shell you have chain length growth which means you near a derailleur type tensioner.
    mtbtires.com
    Reputation: Soupboy's Avatar
    Check out...
    ...Canfield Brothers. They been running SS FR/DH bikes for a while now. In talking to Chris Canfield it seems that his brother Lance who you see in a lot of films has been running this set up for a while.
    Note, they have a unique driveline that helps accomodate this.
    As long as the gearing doesn't prohibit you from pedal kicking the front end up I think it would be a pretty cool idea. That, or get a Nicolai.
    Sean
    Professional Amateur
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    Quote Originally Posted by DHmike661
    Would SS/DH be desireable? It seems like you'd either get spun out easily or be overgeared to set up for jumps and drops just right. Maybe a Rohloff would be a better choice?
    hispanic mechanic
    Reputation: sslos's Avatar
    As long as you can accomidate for "chain growth"...
    Like Shig said, your chain tension will most likely change with suspension travel. If you run a chain just long enough with a short cage road der., you'll rid yourself of a lot of problems. The other factor is, how much pedalling do you have on your courses? If it's like Moab rim/ Tour of the Canyonlands, SS will likely be competitve. Pedalling courses like Keystone? Not gonna be able to keep up.
    the los
    Whiskey is my yoga.
    dongerparty.com
    I've had the same problem on my BigHit..there is one trail in particular that costs me around $75 every time I ride it, for new hanger and derailleur. I have opted to get a short cage Tiagra (cheap road der), and take up all of the slack, and hopefully that will tuck it up under there enough. I don't think the SS thing would work, on my setup anyways...
    Medium?
    Reputation: Fast Eddy's Avatar
    If you ran a Cove G-Spot
    frame, you could rig up a Rohloff 14 speed internal hub with no tensioner. The pivot around the BB gives it a constant chain length throughout its travel.
    It would be the sweet DH ticket, unless you need to go really big with some whacked out Karpiel 10" travel frame.
    <img src="https://shop1.afrobike.de/images/cove-gspot-front.jpg">
  1. Faster on a single speed?
    By Greenfix in forum Singlespeed
    Last Post: 11-18-2004, 12:14 PM
  2. reasonble price production single speed?
    By 24601 in forum Singlespeed
    Last Post: 09-17-2004, 01:04 PM
  3. Replies: 16
    Last Post: 07-05-2004, 01:34 AM
  4. New softtail single speed, Trek STP.........
    By KMan in forum Singlespeed
    Last Post: 07-02-2004, 06:42 AM
  5. Using factory made wheels on a single speed
    By Dimitri Nikas in forum Singlespeed
    Last Post: 01-31-2004, 03:23 PM
