Single speed conversion help- Mtbr.com
Results 1 to 10 of 10
    Apr 2014
    Hey everyone I just set my specialized hardrock up as a singlespeed using a dmr chain tensioner. I have ridden it around my house and down some dirt road to test it out with no problems at all. Well I take it to my local trail today and the at the first hill I stand up to climb and "POW" my chain breaks. I didn't have the tension to tight I don't think. Any ideas where I went wrong?
    Reputation: Awshucks's Avatar
    Apr 2013
    What chain did you use? Did you use the quick link that came with the chain? I think with a broken chain it could be multiple things...
    Apr 2014
    It's a 9 speed sram pc 991 chain. I removed the quick link to avoid a weak spot
    Aug 2010
    check your chain line. if that is off it can break the chain. also, make sure the chain is loose enough that when you backpedal there is no resistance but tight enough that it will not hop off.
    Apr 2014
    Chain line looks pretty good I will test the tension out when I fix the chain
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Quote Originally Posted by tradarcher View Post
    What did you use instead?
    A quick link has never failed me - but a pin joint by me has. So has a pin joint by a pro mech who usually gets things right.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Apr 2014
    I just took enough links out to join it without the quick link. That may be the problem. I think that's where it failed kinda hard to tell though
    local trails rider
    Aug 2005
    You joined it with a used pin from the chain?
    You should not do that. It is a pretty sure way to create a weak spot.
    Apr 2013
    Yeah that's more than likely what did it. Use the quick link
    Apr 2014
    Yea I think thats what I did. My bike shop said my chainline is off to so he's fixing it . thanks guys
  1. Single Speed Conversion
    By rcohenjb1 in forum Singlespeed
    Last Post: 08-26-2014, 04:02 AM
  2. single speed conversion help
    By 94hardtail in forum Singlespeed
    Last Post: 07-11-2013, 04:43 AM
  3. What do i need for a single speed conversion?
    By Perryd in forum Singlespeed
    Last Post: 06-19-2011, 11:12 PM
  4. Single Speed Conversion
    By arkon11 in forum Urban/DJ/Park
    Last Post: 05-20-2011, 12:49 PM
  5. Single Speed hub conversion?
    By backtocali in forum Singlespeed
    Last Post: 03-04-2011, 12:12 PM
