single speed chain tension?- Mtbr.com
Results 1 to 6 of 6
    Reputation: mtbcraig's Avatar
    Mar 2005
    Hello -
    Today I bought my daughter a new, steel, 16 inch, single speed from REI. When we got it home the chain was really loose and the training wheels were kinda loose.
    Without being to verbose, I can't seem to get the chain tight, and simultaneously line the wheel perfectly straight. When I get the chain tight and the wheel bolts on the wheel is always slightly off center. Then of course the chain is pulling at a funny angle and the cranks lock up.
    Thank You for any help!
    Craig
    happy hour is over, and I need two more gears.
    Reputation: East Coast Bender's Avatar
    Shorten the Chain
    Or tighten both nuts at the same time
    Quote Originally Posted by Stinky05rider
    bmx is not dh/freeride....tight jeans are for girls
    Reputation: FODM's Avatar
    Quote Originally Posted by mtbcraig
    If you aren't already doing this, try "walking" the back wheel into place. Face the back of the bike. Pull the wheel back and off-center. The front of the tire should be almost touching the chainstay on the drive side. The chain should be fairly tight. Tighten the axle nut on the drive side. Now push the front of the wheel to the left, centering it between the stays, and any remaining chain slack will disappear. Tighten the left nut. It may take a few tries to get the tension just right.
    “The only Zen you find on tops of mountains is the Zen you bring there”---Robert M. Pirsig
    Sounds like you may be trying to get the chain too tight. There should be a small amount of play in it, not piano-wire tight.
    Mar 2005
    Good job! Thanks Guys!
    Thanks for the suggestions.
    Without my daughter standing over me with the look of dissapointment in her eyes, it lined up fairly easy.
    Maybe I need a SS for myself?
    Craig
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    dang right you do!
    "Knowledge is good." ~ Emil Faber
