I am running a WI Eno crank with a Surley sprocket. What is the thinnest chain I can run?
Originally Posted by louisd I am running a WI Eno crank with a Surley sprocket. What is the thinnest chain I can run? Surly says to use an 8sp chain.
Just one more rep and I get the toaster!
Are you prejudiced against FAT chains?
Originally Posted by hoolie Are you prejudiced against FAT chains? I am whenever they're heavier, weaker & wear out faster. --sParty
disciplesofdirt.org We don't quit riding because we get old. We get old because we quit riding.
This may be a good place to jump in and ask this - is chain type / width more dependent on the chainring or the rear cog?
Forum Rules
