Shop put in gearie cog?!- Mtbr.com
Results 1 to 14 of 14
    you go ahead
    Feb 2005
    I picked up my bike today 3 days after it was supposed to be repaired (Supergo... )
    ok, so first of all, my initial problem was that the chain was constantly making a pretty nasty snapping noise and was basically unrideable. And second, the Singleator needed some inspecting, as I installed the Push Up spring and it continued to push down.
    So I pick it up, and see the mechanic has done 2 things.
    Replaced a plain ss cog with a used casset cog.
    Fixed the chainline.
    So my question is, am I the only one who ran a 8 speed chain with non-gearie cogs and chianrings?
    And will this cog cause any derailling and gauging of the freehub?
    Sorry for all the questions, any help at all will be appreciated
    rb
    which hub do you have?
    pay me
    you go ahead
    Feb 2005
    Shimano Deore Hub...
    the used cassette cog shouldn't be a problem on that hub.
    pay me
    Penis Goat!
    Reputation: GirchyGirchy's Avatar
    Was the SS cog worn? If not, I'd try and get it back. They're designed to keep the chain on the gear, as opposed to cassette cogs, which are designed more for smooth shifting of the chain off of the gear.
    8-speed chains work fine on SS stuff.
    I think you were having problems with your Singleator because you weren't pre-tensioning the spring enough. You need to dial in some tension to keep the spring loaded and pressing up on the chain. You can either use an 8mm cone wrench to hold the spring retainer while tightening the bolt, or swing it around. For instance, if you want the Singleator to end up pointing towards 2 o'clock, tighten the bolt down while it's at 11 or 12 and swing it clockwise. It's there in the instructions.
    Retrograde Customs
    Reputation: dansjustchillin's Avatar
    did you go to the superho in mountain view by chance?
    Retrograde Customs
    Reputation: pacman's Avatar
    based on his location
    Quote Originally Posted by dansjustchillin
    It had to be SuperGone in Santa Monica
    Retrograde Customs
    Quote Originally Posted by pacman
    checked his profile and it just said CA so i wasnt sure. i went to the mtn view one once and was not impressed.
    Retrograde Customs
    you go ahead
    Feb 2005
    thanks for the input so far...
    I forgot to add that the mechainic replaced my 18t cog with a 19t casset cog. So I would be changing it anyways... 19t is too big a gear. As for the Singleator, I'll take yet another look at the instructions.
    But not only did the push up spring push down, but it also got stuck inside the singleator.
    Dont' really know what to do...
    and yes it was the SM Supergo
    Penis Goat!
    Quote Originally Posted by RustyBearings
    Do that. Something's definately not right - take it apart and start from scratch.
    you go ahead
    Feb 2005
    Quote Originally Posted by GirchyGirchy
    did that and followed your instructions on how to tension it... working perfect so far.
    Reputation: sean350's Avatar
    Why Supergo?
    Supergo is notorious for their [email protected] service. I recommend taking it to Helen's in Santa Monica next time.
    -Sean
    Penis Goat!
    Awesome! Those things work fine once they're set up correctly.
    you go ahead
    Feb 2005
    Quote Originally Posted by sean350
    -Sean
    I've gotten better service from Supergo than from Helen's.
  1. WTF? No shop discount after dropping $650?
    By smaledog in forum General Discussion
    Last Post: 08-03-2005, 04:34 AM
  2. Smooth with ur LBS?
    By F*ckinHuckin in forum General Discussion
    Last Post: 05-20-2005, 08:15 PM
  3. Rant: Why I don't shop at the LBS
    By Fast Eddy in forum Riding Passion
    Last Post: 03-10-2005, 10:02 PM
  4. Replies: 43
    Last Post: 08-07-2004, 12:53 AM
  5. shop guys- question for you..
    By kingkahuna in forum Washington
    Last Post: 07-19-2004, 05:37 AM
