Shimano DX Cassette Hub dimensions?- Mtbr.com
Results 1 to 9 of 9
    Candlestick Maker
    Reputation: baker's Avatar
    Dupe post, since I know some people here have built wheels with the
    DX BMX hubs....anyone know the necessary dimensions for wheel building?
    Front and rear.
    http://forums.mtbr.com/showthread.php?t=21718
    baker
    Not a regular
    also posted in the wheels/tires forum
    Front
    Flange diameter: 38mm (center of spoke holes)
    Center to flange: 35.8mm (center of hub to center of flange)
    Rear
    Flange diameter: 54mm
    Center to flange (both right and left - symmetrical flanges): 30mm
    If you give me the rim ERD, I can calculate spoke lengths based on the cross you want. Or go here http://www.bikeschool.com/cgi/spokeprogram.cgi
    Candlestick Maker
    Awesome, thanks!
    baker
    Less yappin, more Brappin
    Reputation: geoffss's Avatar
    for mtb or bmx?
    if i remember correct, the dx bmx rear hub is a 110mm spacing. i knew a dude a long time ago that respaced the axle to 135 for mtb, but kept the distance from the drive side dropout to the cog centerline the same (for proper chainline) basically there were a whole lot of spacers on the non-drive side.
    he ended up building a reverse dish wheel, with higher tension on the non-drive side. it was one of the most retarted things i had ever seen. i dont remember how long it lasted, but he got laughed out of the bike shop he worked in, and he was the manager.
    geoffss
    Candlestick Maker
    Quote Originally Posted by geoffss
    geoffss
    As retarded as "retarted?"
    mtb. I'm hoping to respace for a dishless wheel. I can screw around with bb spindle
    length and chainring placement to work the chainline. If that doesn't work out, I'll convert
    an old xt hub with the bmx freehub to create a wheel with less dish. Since I got the
    hubset for cheap, the whole thing is basically just an experiment.
    baker
    Not a regular
    Quote Originally Posted by baker
    baker
    The spacing, according to Shimano, is actually 112. If you want to respace for dishless on a 135mm rear spaced frame, you'll have to add 11.5mm of spacers to both sides of the hub. Playing with chainline at the bottom bracket should be okay.
    But...the big question might be "is the whole thing worth it?" I know several BMXers who blew up DX freehubs racing. Granted they are big powerful guys, but they blew the pawls out on gate starts. In fact, I don't think Shimano's resident BMX "pro" races on the DX hub.
    Not a regular
    baker
    The spacing, according to s h i m a n o, is actually 112. If you want to respace for dishless on a 135mm rear spaced frame, you'll have to add 11.5mm of spacers to both sides of the hub. Playing with chainline at the bottom bracket should be okay.
    But...the big question might be "is the whole thing worth it?" I know several BMXers who blew up DX freehubs racing. Granted they are big powerful guys, but they blew the pawls out on gate starts. In fact, I don't think s h i m a n o's resident BMX "pro" races on the DX hub.
    BTW - that automatic link to Jenson when s h i m a n o is typed is Bull Sh..
    Last edited by ssmike; 05-07-2004 at 10:27 AM. Reason: automatic link to Jenson when "s_h_i_m_a_n_o" is typed
    Candlestick Maker
    Quote Originally Posted by ssmike
    Cool, thanks for the spacer info. Now I can start tearing apart old wheels looking for
    the right spacers (I don't actually have the hubs yet).
    I don't have any clue if it is really worth it. I've never destroyed a pawl, axle, etc so it is
    all just a fun educational venture for me.
    baker
    Not a regular
    all just an fun educational venture for me.
    baker
    Forgot, to mention that you'll need a longer axle too! S h i m a n o sells solid or QR types that will work. If you are a smooth rider, you'll probably have no problems.
  1. Shimano DX Cassette Hub dimensions?
    By baker in forum Wheels and Tires
    Last Post: 05-05-2004, 02:05 PM
  2. Why no Shimano downhill Nexus hub?
    By henryl in forum Downhill - Freeride
    Last Post: 04-01-2004, 01:46 PM
  3. 9 speed hub with 8 speed cassette
    By Capt_phun in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2004, 11:23 AM
  4. Looking for SHIMANO XT M750 9SP CASSETTE
    By gmascagni in forum Where are the Best Deals?
    Last Post: 03-13-2004, 02:30 AM
  5. Replies: 20
    Last Post: 03-05-2004, 10:20 PM
