Sheldon Brown's gear calculator- Mtbr.com
Results 1 to 2 of 2
    Hi,
    I'm interested in working out equivalent gear ratios, i.e. when does 32x16 require the same amount of effort as 36x18?
    The reason is I've got a Surly 1x1 using 32x16 and have a 38 tooth chainwheel which I fancy trying on my cross check with 28(9)" wheels
    I've been playing with the calculator and have a the following numbers
    For 26"
    32 - 34 - 36
    14 - 4.3 - 4.6 - 4.9
    16 - 3.8 - 4.0 - 4.2
    18 - 3.4 - 3.6 - 3.8
    20 - 3.0 - 3.2 - 3.4
    Is it true that 32x16 = 36x18 (3.8) or than 32x18 = 36x20 (3.4)?
    For a 27" wheel (not quite a 700c 29") wheel but I hope you get the idea of what I'm aiming at.
    32 - 34 - 38
    14 - 4.5 - 4.8 - 5.3
    16 - 3.9 - 4.2 - 4.7
    18 - 3.5 - 3.7 - 4.1
    20 - 3.1 - 3.3 - 3.7
    Is [email protected]" (3.8) feel about the same as [email protected]" (3.9)
    if you ignore tyre choice, surface area etc.
    I understand that 29" bikes require a 10% higher gear than 26" due to a 10% bigger wheel. I'm just looking to make comparisons via Sheldon's calculator. It's a very nifty thing BTW.
    Rob
    Reputation: pacman's Avatar
    Quote Originally Posted by English Bob
    Hi,
    Rob
    Always the same effort (on the same bike).
    If you're trying to convert to a 29" bike then you've come close enough in your calculations. What you "feel" is going to override the accuracy of the calculations, unless you account for the greater rotating mass of the larger wheels, which means slower accelaration for the same effort.
  1. Does pushing a bigger gear make you faster?
    By Motivated in forum XC Racing and Training
    Last Post: 04-23-2004, 01:20 PM
  2. disc + freewheel + fixed gear?
    By qtip in forum Singlespeed
    Last Post: 02-13-2004, 08:04 PM
  3. Mountain Bike Calculator V3.0 (2004/02/13)
    By FireDog46 in forum Shocks and Suspension
    Last Post: 02-13-2004, 11:13 AM
  4. Replies: 1
    Last Post: 02-13-2004, 10:13 AM
  5. Mountain Bike Calculator V2.0
    Last Post: 02-04-2004, 07:33 AM
