serious about converting this time- Mtbr.com
Results 1 to 10 of 10
    out of shape
    Reputation: den9's Avatar
    i thought about it and now im serious, i want to go ss. i need help though
    for the front i want a bash guard, but dont have those fancy mounts, what do i need to mount the e thirteen on my bike?
    for the rear i want to use my stock hub, what do i need to do about spacers?
    do i need a tensioner? its a hardtail.
    also can someone point me in the right direction for flip flop hubs? i have rim brakes
    do i need a new freewheel also?
    if i do what thickness for the sprockets and chain?
    sorry for all the questions, the only thing thats holding me back is i dont know what i need
    doylestown pa
    SS cannondale F6
    I just got a ss conversion kit, a tensioner, and happily trashed my derailleurs/shifters with joy. Just borrow a friend ss and go for some rides before you commit to it. I do not think you have to take this as a very serious matter...riding is about having fun either geared or ss.
    you can buy full conversion kits online and the bashguard just replaces the big ring up front held on by the chainring bolts
    Reputation: Nater's Avatar
    First, read the FAQ link at the upper right of the page.
    http://www.mtbr.com/faq/ssfaq.shtml
    You have a lot of questions here, some are redundant...
    If you're going to use your current hub with a cog and spacers, you don't need a new freewheel or a flip flop hub.
    You'll probably need a tensioner unless you want to play around with finding your magic gear.
    SS stuff is generally compatible with a 3/32" chain unless it specifically says it's for a 1/8" chain.
    out of shape
    so my multi gear rear hub is considered what type of hub?
    doylestown pa
    SS cannondale F6
    Turn off the TV
    Reputation: SMT42's Avatar
    Nov 2006
    Well... it's an 8/9 speed hub. Just buy a kit and that will be all yo need. Performance Bike $25.00 or so. You don't need anything else, provided you have some tools. One other thing, try researching a bit there is a great deal of information out there. Sheldon brown's web site is great, may he rest in peace.
    Teen Wolf
    Reputation: cr45h's Avatar
    also, the e13 will just bolt on assuming you buy the right mm and bolt pattern
    out of shape
    i did some research and im gonna order all this stuff tonight, but i need to make sure i got the right stuff
    http://www.pricepoint.com/detail/151...og-Spacers.htm
    or would this work just as good? http://www.pricepoint.com/detail/134...ersion-Kit.htm
    http://www.pricepoint.com/detail/149...E.Thirteen.htm
    doylestown pa
    SS cannondale F6
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    The adjustability of the Rennen spacer kit is nice for getting chainline exactly right. You will still need a cog and a tensioner.
    The Gusset kit will probably work fine. You still need a tensioner.
    Those E-13 bashguards will fit, if your cranks are 4 bolt.
    out of shape
    i just bought a e13 supercharger bashguard
    gusset ss kit
    and a sette tensioner
    should be here in 2 days, i hope it works out
    doylestown pa
    SS cannondale F6
