SC chameleon disk brake adapter- Mtbr.com
Results 1 to 6 of 6
    Does your dog bite?
    Reputation: vova's Avatar
    Trying to find the install directions for the disk brake bracket for a 2000 Chameleon. I saw something on line but can't find it any more.
    Jesus loves you, everyone else thinks you're an a-hole.
    Reputation: homegrown_xt's Avatar
    hope this link helps, I just bought one for my ss chameleon about 2 weeks ago.
    http://forums.mtbr.com/showthread.ph...cruz+chameleon
    Reputation: brassnipples's Avatar
    Feb 2006
    I went through this, I'm not sure if mines a 99 or a 2000 but it required drilling a hole for the adapter. It's not difficult but I drilled mine by hand and the hole is ever so slightly off, it's worth taking the time to find someone with a drill press to get the hole just right. FWIW the hole being slightly off doesn't seem to be a problem it just required a little filing to get everything to line up just right.
    I didn't drill the extra hole but I did have to grind down the drop out a little bit to get the adapter to fit flush. I called Santa Cruz and talked to a tech before I did it to make sure that it wouldnt affect the integrity of the frame and he said it would be fine as long as I didn't grind into a weld or take too much material off of the drop out.
    Here is a picture of where I did the grinding:
    Attached Thumbnails Attached Thumbnails SC chameleon disk brake adapter-cimg6291-1.jpg
    where can i get this kit, im getting a 99 or 2000chameleon frame myself and would love to be able to put discs on the rear
    heaven help me
    go to the santa cruz web site and click on the store. i have a 2000 chameleon and the only problem i had was the avid rear caliper hitting the bottom of the chain stay. had to do a little filing to get it to fit right.
