SASS Specific; stopping the seat post from slipping- Mtbr.com
Results 1 to 6 of 6
    Retro Grouch
    Reputation: aka brad's Avatar
    The aluminum seat post on my SASS has always slipped and there seemed nothing I could do about it. Then, remembering about my slipping fork ends caused me to dremel out a small about of material from the seat tube. It may seem counter intuitive but it worked! No more slipping. I know why, do you?
    Just one more rep and I get the toaster!
    Mtbr Forum Sponsor - Homebrewed Components
    where did you dremmel out the material? i assume under where the clamp goes so it would compress the frame into that void to prevent it from slipping?
    Retro Grouch
    Quote Originally Posted by ISuckAtRiding
    The material was taken from the first 3/8" inside of the seat tube.
    smell the saddle...
    Reputation: stumonky's Avatar
    What are you using to hold it in place? QR, binder bolt, other? Mine was doing that on my Muss until I switched to a binder bolt.
    Retro Grouch
    Quote Originally Posted by stumonky
    I am using a binder bolt. I determined the cause of the slipping was residue chrome plating on the inside of the clam area. Once I ground it out the seat post stopped slipping.
    Low Rep Count
    Reputation: 1SPD's Avatar
    Hence reaming out the tube! I also use a carbon prep on mine. I was having a horrible time w/ my Blue RC8 (carbon frame) and my carbon post. Since the stuff can be used on either alum or carb I now put it on my bars (carbon bars-alu stem) and my post which is now alu and all is working great.
