Santa Cruz Chameleon SS With Rear Disc- Mtbr.com
Results 1 to 9 of 9
    WWW.TYPE1RIDER.COM
    I am looking for a little bit of help getting a rear disc setup on my 2003 Santa Cruz Chameleon SS. The 2003s and up have the build in disc tab, and I have yet to find anyone who has an optimal setup for running a rear disc during SS operation.
    I have heard that a 34/18 puts the rear hub in perfect position, but I don't know if that is true. Plus I am guessing with chain stetch that it probably won't work well for all that long.
    I thought about maching the existing disc mount to have slotted mounts (like a Surly 1x1), thus allowing me the slight variations I will need.
    I am fishing for a solution. I am running a v-brake back there now, and it is all good. But man, I would like to find a disc solution...
    If anyone has any ideas, I would love to hear them.
    2WheelFreak
    [email protected]
    'Who ever said you couldn't run away from your problems, obviously wasn't riding fast enough!'
    USB Rep'n
    Reputation: namaSSte's Avatar
    no solutions but I do have a question.....do you have to remove the caliper if you are using a disc w/ those horizontal dropouts? I am hopefully going to have my 2004 Chameleon next week and wondered about this. Im starting by running a disc up front and v's in the back. After I see it, I guess I'll decide.
    For your question page eSSq or SDizzle, they know all that is lizard!
    though hope is frail, it must prevail - Taj Weekes
    betam eh-wud-eh-HA-lehu y
    eh-nay Ityopia!
    Reputation: Robin1's Avatar
    Rear Disk on Chameleon
    I have a 2004 Chameleon running Avid mechanical in the back. I first rode 34/18 and now I ride 34/20 and have no problems with set up on either. I use a half link though. And I don't have to take the caliper off to change out the wheel. I suggest you take it to your LBS and have them help you out.
    Support your local bike shop, unless of course, you can get it cheaper online.
    Reputation: Nimai's Avatar
    try over on the sc board.........
    over there under "post your lizards." lots of folks with chameys running discs. 04's, 03's and older. someone is bound to have a set up that fits your bill, otherwise try SC. [email protected] knows his stuff and could surly help you. hope this helps.
    It's all cycle-logical to me.
    Whiskey Tango Foxtrot
    Reputation: eSSq's Avatar
    Good job! ^^^ what he said ^^^
    except i'm not using a half-link. robin, why are you doing that? when i switched from 32:18 to 34:20 i just added a regular link to my chain and then slid the tabs forward about 2 mm. works great on my 2004 XL.
    the chameleon is such a b:tchen bike. i am enjoying min very much. anyone want to buy my bianchi? i fear i may never ride it again!
    theHeadlessThompsonGunner
    Reputation: SDizzle's Avatar
    You won't be able to machine the mounts, and will likely trash them trying to do so. My recommendation, if for some reason eSSq's suggestion doesn't work (32 x 18, 34 x 20), would be to have a good shop order you the upside-down mount from pre-2003 Chameleons. It will still fit, and then you won't have any issues whatsoever - plus, you can remove your rear wheel without loosening the caliper.
    "I've courted brain damage like some courtesan of darkness."
    -The Good Doctor
    Half link is the way.
    Well I'm not using the tension spacers from SC that your supposed to use if you want to ride it with a derailer and my frame is a large. I don't know if the chainstays are different sizes but I like my chain on the tight side. I have a 2000 Chameleon frame and RS Duke Race fork in case anyone is interested.
    WWW.TYPE1RIDER.COM
    Thanks a lot! Those are some great suggestions!! I currently run a 32/18 and will try it with that setup.
    You guys rock!!!
    Thanks!!!!!
    2WheelFreak
    [email protected]
    USB Rep'n
    Quote Originally Posted by eSSq
    and the pictures of it are where????? I know, you're having too much fun riding it to take its pic. Either that or its camera shy because I know its not because you are procrastinating.
    eh-nay Ityopia!
  1. Santa Cruz Syndicate
    By george_da_trog in forum Santa Cruz
    Last Post: 05-23-2015, 10:33 PM
  2. Chameleon with rear disc
    By CJLED in forum Santa Cruz
    Last Post: 08-10-2004, 12:29 PM
  3. Santa Cruz team rear shock?
    By primopro250 in forum Downhill - Freeride
    Last Post: 04-20-2004, 09:18 PM
  4. santa cruz chameleon
    By chris_m1 in forum Bike and Frame discussion
    Last Post: 03-09-2004, 04:23 PM
  5. Santa Cruz Blur vs Specialized Stumpjumper FSR Pro Disc
    By Sierra Azul in forum Bike and Frame discussion
    Last Post: 02-17-2004, 08:03 PM
